Originally Posted by
oreos40
thank you much!
next couple questions.
How do I remove a program that is loaded into memory on this control.
To delete program O1234, in EDIT mode, type O1234 and press the DELETE key.
What line of code do I need to have the control automatically return to the beginning of the program so that I don't have to manually reset it?
M30
In my program I have set the work zero point as the first movement line of code, from there I go into incremental for the part and machine the part. It would be nice to do a grouping of ten offset in y by 2.312 inches for each can I create a subroutine and just offset to the next start point. I know there are six programmable work "zero points" but with ten in a group is there another way to program them off of a single start point and have the machine return to this point after the group is done for reloading?
