Originally Posted by
moldmker
One possible cause that I see:
Looks like you translated the contour after creating it.
This is apparent because I exploded it and it jumped to another position.
(when a contour is created, the source geometry is blanked out)
Not sure if it's the root cause of your problem, but that has given me unpredictable results in the past.
If I need to move a contour, I explode it first...move the entities...recreate the contour.
Again not sure if that's the problem (don't have my dongle with me to fully run BC).
moldmker
EDIT: Seeing woffler's reply.....is that mark a divot in the path or is it a mismatch of the start of path to the end of path?
His reply would address a divot...my reply would address a mismatch.
