586,075 active members*
3,993 visitors online*
Results 1 to 3 of 3
    Nov 2010
    AHVC gone crazy...
    So I'm gonna go batty....table has been working pretty good. The machine torch holder setup is a little worn out and has a little play. Saturday we made a bracket to change the angle so that we could mount the plate marker and life was good. Then we cut out several things fine, and then went to cut out a sign and the ahvc hung up on one letter, and after that everything went down hill. If i use the control box to move it up and down its fine but if I turn the plasma on, like to set pierce height, its opposite. Plasma on torch goes up....plasma off torch dives down into materiel. I didn't change anything (that I am aware of or on purpose). It started doing this after it hung up. I am currently using the torchmate red display AVHC. I am using a hypertherm 1650.
    May 2008
    39
    did u check the fuse in the avhc box?
    bakerj99
    Nov 2010
    Fuse was fine. After talking with torchmate the recommend a gaurd reset...which is just unplugging the whole unit for ten minutes or so. Works fine now.
  1. Crazy Idea...
    By twocik in forum Tormach Personal CNC Mill
    Last Post: 08-24-2010, 04:33 AM
  2. New crazy idea....
    By pete from TN in forum Benchtop Machines
    Last Post: 04-26-2008, 12:05 AM
  3. Going Crazy...heh kinda
    By ColdCnc in forum Waterjet General Topics
    Last Post: 11-14-2007, 12:02 AM
  4. The crazy stuff you used to do
    By Steve@Reliance in forum Community Club House
    Last Post: 06-26-2006, 05:40 AM
  5. LPT crazy
    By Lu_ca in forum DNC Problems and Solutions
    Last Post: 04-06-2005, 12:17 AM
