586,067 active members*
5,287 visitors online*
    Apr 2004
    353
    Re-tapping a hole VF-7
    I just started working with this Haas machine two months ago. Anyway, today I had to tap my first holes (1/4-20). So I tapped them all first to the depth that I thought I needed, and ended up having to go 1/16" deeper, so I adjusted my "Z" value in my G84 line and re-ran the holes. Well the tap started to cut immediately on the first hole and eventually broke?
    So this thing does have rigid-tapping, but does it not orient before each hole? To me it looks like it just starts from wherever the spindle happens to be at the moment?
    4826
    There is also a 'repeat rigid tapping' parameter to turn on. Maybe that is what that is for, so it will use the encoder index as a start point!
  1. Trouble tapping a blind hole
    By subi4ester in forum Haas Mills
    Last Post: 10-29-2010, 10:24 PM
  2. deep hole tapping problem
    By ak_crabber in forum MetalWork Discussion
    Last Post: 02-06-2009, 12:44 AM
  3. Single Op Through Hole Tapping
    By GHPoe in forum MetalWork Discussion
    Last Post: 12-20-2008, 07:22 PM
  4. Tapping a hole twice in a HMC
    By Appetite in forum MetalWork Discussion
    Last Post: 05-02-2007, 04:30 PM
  5. small hole drilling & tapping
    By dneisler in forum MetalWork Discussion
    Last Post: 02-10-2006, 03:54 PM
