586,062 active members*
4,608 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Waterjet General Topics > Precision hole techniques for an inexpensive setup?
Results 1 to 18 of 18
    Jun 2008
    16
    I'm attempting to squeeze as much precision as possible out of my Torchmate 2X2 + Harbor Freight plasma + manual torch height z-axis. I'm not a professional, so can't justify the more expensive plasma cutters out there, nor an AHVC, nor an air conditioner.
    My holes are getting tapered at different rates across the circumference. I'm working with 0.25 CRS. The amperage and air pressure is set at the highest level. The lead-in edge is good, but it tapers in as it works its way around. I've tried feedrates from 10 down to 3 ipm. While watching it from the side, it is clear that the cut isn't piercing equally throughout the travel around the circumference. It veers off towards the middle. I assume that this is because the material is more hot near the middle, thereby melting more quickly and causing the cut to wander into it. I don't think its because of a damaged nozzle because straight cuts look OK.
    I thought it might be possible to try a spiral pattern from the center. The idea is to heat the material equally around the circumference, get it close to melting temp, and blow out a clean edge for the last pass. I'd experiment with different speeds to minimize dross. Maybe even change the speed on the last pass?
    Any other techniques? Has this been tried before?
    Mar 2009
    924
    Quote Originally Posted by jurban View Post
    If you think it might be heat, try a pump-up sprayer (the kind used for bug spray/weed killer) filled with water and spray it down while cutting. That would be a cheap start. If that works, then a water table would solve it. :drowning:
    Jan 2008
    2247
    The plasma arc on many plasma torches has a natural lag while cutting. You can se the lag angle if you look at the lag lines on a piece of steel you have cut. Now think about that lag angle as you cut smaller and smaller hole diameters....as the machine keeps turning left to produce a small hole, the lag angle follows and produces a taper.
    Better plasma torches produce an arc with higher energy density....which means the plasma just has a higher velocity and a stiffer, narrower arc. Developing this technology requires engineering with high temperature physics, and that does not come cheap!
    The other critical components of getting good hole quality are covered in this description of how to get decent holes with an air plasma:
    For best quality on holes:
    -I pierce at about 1.5 to 2 times the recommended cut height.....so if cut height is .062", pierce at .125".
    -Use a lead in that gets as close as possible to the center of the hole for 2 reasons: 1. There usually is a slag puddle on the top of the plate..if this puddle stays on the radius (contour) of the hole, it will cause the plasma arc to waver and create a divot or ding in the hole. 2. A longer lead in gives the plasma arc time to stabilize (pressure and energy take a while to ramp up), also allows the height control to index down to cut height before it gets to the contour of the hole.
    -With an air plasma, it is best to have no lead out. Let the arc shut off right at the 360 degree position on the hole contour. Some software has provisions to keep the arc on for a time period after the motion stops....on steel under 1/2" this usually is not necessary.
    - Cut speed on holes should be right at about 60% of the speed used to cut the outside contour of your parts....this will create some low speed dross on the bottom of the hole, but will minimize taper in the hole. Some machines will do this automatically on all holes under a certain diameter, such as 1", while other software may have to have the G Code manipulated to achieve this.
    -Ensure that cut height is correct. Usually on holes under 1" diameter it is best to disable arc voltage control....allow the pierce height, allow indexing to cut height, but don't allow arc voltage height correction...as the slower speed used for cutting holes will cause the arc voltage height control to move the torch too close to the plate.
    -Try spraying some mig welding anti-spatter spray on the top of the plate before cutting. You may be surprised at the improvement in hole quality. The spray usually makes the top spatter from piercing non -existent,minimizing arc wobble on holes. While you are at it spray a little on the front of the torch to keep spatter off the shield/nozzle. Do not use the dip type, and I recommend the water based spray vs silicone or oil based.
    -last, but not least....use the lowest powered consumable set recomended for your material thickness for best hole quality. This will reduce cut speeds but will give you better results. If it is Hypertherm use FineCut consumables for all holes on material thicknesses under 3/16", 40 Amp shielded consumables for thicknesses above 3/16" to 3/8", 60 Amp consumables for thicknesses above 3/8" to 5/8".
    The nozzle and shield orifices must be perfectly round, no nicks, dings or craters. Inspect with a 10x eye loupe....if they are not perfect, use these parts for hand cutting or contour cuts that are not as critical. The orifice shapes the arc, the arc shapes the part you are cutting. Piercing too close or too thick can damage a nozzle orifice in one pierce.
    So....to get the best precision on holes...you need to use the correct programming techniques, you really need a torch height control system, and of course a good plasma (plasma systems are not all equal)
    I have a .pdf presentation on best practices for hole quality. If you provide me your direct email I can send it to you. My email is [email protected].
    Attached are some pics of holes that I cut with my 4 x 4 cnc equipped with a Hypertherm Powermax45 and a full function THC....And yes....you will notice some 1/4"-20 tapped holes in a couple of the pics. When I want to make the highes presicion holes, I program them slightly undersized with the plasma, then drill them out with a cobalt drill bit (the holes are nitride hardened from the nitrogen content in the air plasma jet)...in this case I cut them at .188", drilled to .201", and tapped them easily to 1/4"-20.
    Jim Colt
    Attached Thumbnails Attached Thumbnails IMG_2358.jpg   IMG_2360.jpg   IMG_2944.jpg   IMG_2945.jpg
    Feb 2008
    153
    Try reversing the cut direction, you may be going the wrong way.
    Like Jim I also make the holes slightly undersized and finish them on the drill press. I use a straight flute reamer, it seems to work better than a drill bit.
    I don't think your spiral idea will work well. My machine (ESAB) cuts best when the arc is "supported" by metal on both sides.
    Jan 2008
    2247
    Plasma cutting is directional.....holes should be cut counter clockwise. If you are cutting a ring, the ID cuts counter clockwise, the OD cuts clockwise.
    Actually....the only holes that I normally drill are holes that need the edges to be soft, such as for tapping. The vast majority of holes that I cut for bolt holes are accurate enough without drilling by using my hole cutting techniques, and a Hypertherm plasma system. I cannot make that claim for plasma systems that are older technology, or are not Hyperthem brand as my experience shows me that the cut edge angularity is not adequate to remove the taper in holes....no matter what technique is used!
    Jim
    Feb 2008
    153
    Quote Originally Posted by jimcolt View Post
    Unless you have the swirl ring in backwards, which is possible with some torches.
    Jim
    Whoa, hold on there! I'm not giving you more ammo for your "Hypertherm or nothing" campaign. I was not implying that I drill/ream every hole, I was just adding to what you said. I ream them when I want a precision hole, but for general through holes my Esab does just fine. I know it's hard for you to believe that anything but a Hypertherm can make nice holes, but it's possible.
    Oct 2005
    378
    Quote Originally Posted by Fiero Addiction View Post
    Fiero,
    Apparently you have not heard of Hypertherm True Hole Technology:stickpoke
    Mar 2009
    924
    Brands aside, if you use Jim's guide you will get nicer holes. We use a Hypertherm machine that is considered by many "entry level" (pm1650) and it is a cutting fool. round holes with little taper within .030"
    WSS
    Feb 2006
    133
    'Whoa, hold on there! I'm not giving you more ammo for your "Hypertherm or nothing" campaign."
    As a Thermal user all I can say is I have learned more from Jim Colt's posts on here and other places than I have from the factory guys that represent Thermal Dynamics.
    Don't take that the wrong way as they have helped a great deal but all you have to do is a little searching to see that Jim is a wealth of information.
    Period.
    I have two Thermal machines and if Hypertherm would have a buy-back promotion I would probably switch! If for no other reason than the on forum support.
    End of rant!
    May 2007
    250
    Smile hole quality
    Jim Colt
    Jim,
    Thanks so much for the good idea.I am little puzzled with spray as red statement. I can not imagine how is the appearance of spray. Do you have the sample picture of this one?
    Mongkol
    Feb 2008
    153
    Quote Originally Posted by tinman13 View Post
    No doubt, Jim's posts are always very informative. I have learned quite a bit from him as well, he is an asset to the forum.
    Jim, sorry if I've offended you, that's not what I intended.
    Jan 2008
    2247
    You can certainly use my techniques with any brand and model plasma cutter! You will see varying degrees of improvement based on the design and condition of the plasma. While I have worked with many brands of plasma systems over the years...my expertise is primarily with Hypertherm systems. I'm not here to blatantly advertise, just to offer my knowledge and expertise that may help with your plasma cutting processes regardless of brand.
    Mongkol.....I guess I don't understand your question in regrds to the use of anti-spatter spray.
    Jim
    Mar 2009
    924
    On the subject of anti-spatter, It does work! Holes are truer with less taper and certainly more concentric. On large nests, I try to find the hole line so to speak and run a pass of spray type anti-spatter across the plate to coat the surface, a little dry time helps even if it is only a few seconds. I quite coating the nozzle/electrode after a few toasted parts. The internal parts repel against the anti-spatter.
    WSS
    Oct 2005
    378
    WSS, the anti splatter sounds like a great idea. I was looking at the Komatsu Plasma website and noticed that their plasma tables automaticly spray the surface with anti splatter before every pierce. I'm going to give it a try.
    http://www.komatsuplasma.com/kai/ctd...patter_800.jpg
    You can see it in action on their video;
    [nomedia="http://www.youtube.com/watch?v=IYCMulb0528&feature=related"]YouTube - Komatsu Twister TFP3051 Fine Plasma Cutting System[/nomedia]
    Magma-joe
    Mar 2009
    924
    Anti-spatter follow up
    I just got in a five gallon bucket of water based anti spatter. I picked up a one gallon sprayer from lowes to apply it, but the mist is not fine enough. I ended up using a sure shot can that worked very well. Ended up dilluting the spray by adding about 30% water. The first application went on to thick out of the pump sprayer and I had to use a brush to spread it evenly. Another con of too thick is post cut clean up. I will try tomorrow using the watered down mix in the pressure sprayer.
    I did spray both sides of the plate just to see what the results would be. I will skip the bottom next time. There was less dross but not enough to deal with the clean up.
    WSS
    Attached Thumbnails Attached Thumbnails Photo104.jpg   Photo105.jpg   Photo106.jpg   anti spatter.jpg
    www.metaltechus.com
    May 2010
    25
    Nice cuts, they look great. I would never have thought of anti splatter as a form of reducing dross
    Mar 2005
    79
    I've used anti-spatter spray from aerosol cans in the past for welding, but could not stand either the smell or the sticky mess it left behind. The ones I used smelled something like rancid fried fish, and were difficult to clean up after. Does the water based stuff smell like that? How about cleanup?
    Mar 2009
    924
    dpac, It does help a little on the underside. The big benefit is on small holes where the cut may cross the topside dross crater and chatter or stick if it is still hot enough to grab the shield.
    panozeng, This stuff took me awhile to figure what it reminded me of. My weld shop foreman nailed it and said it reminded him of leather conditioner. It does, same feel and smell. Clean up was an added chore. Usaully I would flex wheel grind rust and sharp edges but the wheel loaded up pretty quick, so I used a wet rag to wipe up the mess. I did put it on thick. I will play with it to see what I get today.
    It did have a distinct smell, not like fish but different.
    WSS
    www.metaltechus.com
  1. Precision CO2 laser hole trepanning on ceramic
    By KCKnight in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-19-2009, 07:51 PM
  2. Precision hole drilling?
    By sp1nm0nkey in forum MetalWork Discussion
    Last Post: 11-20-2007, 07:30 AM
  3. job setup -round whit a hole
    By osomaker in forum Mastercam
    Last Post: 12-21-2006, 03:51 PM
  4. Best inexpensive servo setup for small 2x3 table
    By Ed Williams in forum Servo Motors / Drives
    Last Post: 08-28-2006, 01:03 PM
  5. Inexpensive Closed-loop Stepper Motor Setup?
    By lazlo in forum Stepper Motors / Drives
    Last Post: 04-18-2005, 03:53 PM
