586,102 active members*
2,601 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol > Error in table position for z axis, Mazak FH6800
    Aug 2010
    14
    I performed ABS posotion repair in MRJ2 unit for pallet changer in Mazak FH6800 machining center. Now my table position for z axis is changed. Pls provide guidance how to rectify the error in position of table.
    Sep 2008
    93
    Quote Originally Posted by sonu View Post
    open the MRJ2 software.
    open the parameter display
    read the parameter
    open test operation display
    (in mazatrol unclamp table)
    in test operation move the table in the correct posicion.
    for the new zero, select (absolute position inicial set)
    push origin set
    push normal rot
    the table will move and stop. and it takes the new zero.
    (clamp table)
    an move the table at zero point in MDI.
    review the Zero.
    Aug 2010
    14
    Thanks mantenim, i will perform the suggested rectification and check.
    Aug 2010
    14
    Dear mantenim, the procedure given by you seems to be for position of table rotation i.e. B axis while i need for position of Z axis. you can help in this regard. Thanks
  1. mazak fh6800 atc driver alarm
    By waseem sajjad in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-07-2010, 01:46 PM
  2. Mazak FH6800
    By spartus333 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-31-2010, 07:07 PM
  3. OLD UHU POSITION ERROR
    By dfv in forum UHU Servo Controllers
    Last Post: 03-22-2010, 06:16 PM
  4. Mazak M2 home position
    By jjsells in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-03-2009, 12:35 AM
  5. Mazak Integrex 1060v8 c axis position errors
    By Bushman in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-29-2007, 10:28 PM
