587,076 active members*
3,310 visitors online*
    Jun 2004
    450
    Carbon Fiber and other composites
    Afternoon all. I start a new job on the 18th of this month, and need a bit of info. The company works (as far as I know) with only composites, with the exception of building the tooling for said composites. Carbon fiber, fiber glass, and a bunch of others that I can't pronounce. Fiber glass is considered a composite, right?
    They currently have 2 machines. One smaller Haas 3 axis and a 5'x10' Thermwood 5 axis with rotary (articulated?) head. They mainly use the thermwood to trim parts after forming/molding/whatever the process is. The Haas seems to be used for machining foam cores.
    The main info I am looking for is anything related to machining composites. Recommended cutter types/geometry (will regular carbide endmills just not work?), speed and feed considerations, recommended SFM, chipload, etc.
    I don't know the specifics of the machines (RPM and feed capabilites), but just want to get a bit of a headstart.
    Thanks.
    Dustin B.
    I hear and I forget.
    I see and I remember.
    I do and I understand.
    Onsrud makes router bits for cutting composites. They also have chip load charts in their catalogs. http://www.onsrud.com
    Feb 2007
    246
    I machine a lot of fiberglass, mostly turning with a little milling.
    I have found that uncoated carbide running at 250 to 290sfpm, works really well its super slow but its makes the cutters last fairly well.
    Solid carbide endmills last good but the lathe tooling is different. I have been using alum grade inserts for turning because they have a nice sharp edge with a very positve chip breaker. Coated inserts dont work very well and heat a lot, due to the coating making a slightly dull cutting edge.
    I have been using a PCD ( diamond ) grooving tool for parting off fiberglass tubing and it has lasted monthes, but is super pricey.
    I looked into onsrud cutters and they are meant to run high RPM and cost a fortune. Most good manufactures make diamond coated solid carbide endmills for a lot cheaper, that is what I am going to try out for higher production numbers.
    Its a entire different thing machining fiber glass, and glass plastics.
    (edit... wow this is a really old post)
    Mar 2004
    1661
    Yep, this one is pretty old...
    Just a comment to anybody who reads it, glass nor carbon fibre are composites - BUT when they're mixed with resin they will be. When two ingredients are used together to get new characteristics it's a composite. Even glued wood such as plywood is one.
    Regards,
    Sven
  1. Carbon fiber
    By turmite in forum Composites, Exotic Metals etc
    Last Post: 01-08-2014, 03:57 PM
  2. Carbon fiber sheets
    By aghobby in forum DIY CNC Router Table Machines
    Last Post: 04-19-2004, 05:29 AM
  3. Carbon fiber
    By CNC Pro in forum Community Club House
    Last Post: 03-13-2004, 11:32 AM
  4. carbon fiber
    By teilhardo in forum Community Club House
    Last Post: 03-05-2004, 11:40 PM
  5. carbon fiber
    By Hobbiest in forum DIY CNC Router Table Machines
    Last Post: 01-23-2004, 10:40 AM
