I am looking for a Rebuilt Spindel for a 1997 Okuma Cadet. Cat 40 or a good place to have mine Rebuilt. Also would need taper reground.
Gary 816/847/1100.
Gary 816/847/1100.
Machine Tool Bearings and Accessories of Elk Grove, IL can professionally rebuild your Okuma Cadet spindle.
We are very familiar with this model spindle. We provide you with a turn-key service. From bearing replacement, "O"rings, Labrinths, Spieth lock nuts, to Belleville washers for the draw bar. We can also regrind and correct the taper. If need be, we can repair the shaft journals and/or housing by grinding, hard chrome plating, and grinding to return to original sizes. All spindles are test run-in at our facility to verify temperature and vibration.
Give Joseph a call at (847)357-1793
