586,119 active members*
3,648 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Passivating Stainless Citric or Nitric
    Apr 2010
    260
    I've seen debates back and forth about what is the best acid for passivating stainless. Typically the argument goes between three issues, 1 environmental, 2 chemical reactivity, and 3 alloy specific to the 2 acids.
    I was wondering if anyone has set up their own passivation tanks in their shop and if so what acid do you use, best source for the acid and what is your preferred procedure to passivating, like dilution rate, soak time, acid bath temp.
    www.machmachine.com
    Jul 2009
    419
    Re: Passivating Stainless Citric or Nitric
    Question is 10 years old and counting, I found it in researching the topic.
    So far I found that citric acid is often better.
    Requires 4% solution, between 70 and 160 dgr F and more than 120 minutes does not do much extra.
    https://ntrs.nasa.gov/api/citations/...0110001362.pdf
  1. Passivating Heat Treated Stainless Steel
    By msomerville in forum MetalWork Discussion
    Last Post: 01-20-2015, 05:17 PM
  2. Stainless or non stainless steel ACME screws?
    By amanmazleigh in forum Linear and Rotary Motion
    Last Post: 07-07-2011, 05:00 AM
  3. Has anyone cut 13-8 stainless
    By crazymat14 in forum MetalWork Discussion
    Last Post: 04-12-2011, 11:11 PM
  4. 316 LVM Stainless
    By Arran in forum Australia, New Zealand Club House
    Last Post: 02-06-2011, 05:19 AM
  5. Stainless 304
    By pauls in forum MetalWork Discussion
    Last Post: 06-04-2005, 09:50 AM
