A few moths ago I acquired a DM4400. I made some progress getting it up and going yesterday.
With the machine hooked up to a rotary phase converter, and the key switched to “on” the machine would not initialize when the “on” button was pushed. I followed the trouble shooting flow chart and checked out the items the best I could, and found no apparent problems. Then I manually engaged the main power relay. The computer initialized. I checked turning it off and on via the off / on buttons, the machine shut down and restarted normally. I thought I got lucky and the main power relay had just frozen up, and that by exercising it manually it had freed it up. Then I shut the whole works down, phase converter and all, re powered up, and I was back to square one. Tried operating the main power relay manually, but it would not hold. I checked out the time delay, all the contacts looked good.
Looks like I will be spending some time getting to know the wiring diagram for this machine.
The two things left on the trouble shooting flow chart are a further checkout / bypass of the timer delay, and to check the voltage at “+5/+12/-12 vdc and 55 vdc power supply”.
Has anyone experienced failure of the time delay?
Can someone direct me to where the 55 vdc power supply, I am assuming a transformer is located?
Also are there any other interlocks I should me aware of? The only one mentioned in the flow chart was the door switch. I am thinking there may be an air pressure interlock. I am going to repair the air line next. Sometimes when I hit the “on” button I hear a clicking near where the air line goes in at the spindle. The trouble shooting flow chart did not have that on the list of things to check for start up problems, but I might as well fix it and see if it helps. I will keep my fingers crossed!
As for the RPC I get 120 to ground from 2 legs, and 240 to ground on the 3rd. Between legs I get 240 on 2 sets and 260 at the 3rd set. We put some thought into where we put the high leg. 2 circuits had branches before the main power relay, we put the high leg on the 3rd circuit that did not have a branch prior to the main relay. Is it safe to start moving the high leg around and trying it out? Or am I running the risk of frying electronics?
