586,121 active members*
3,643 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > G-Code Programing > write gcode for circle with 4 small circle inside it
    Sep 2010
    hello.I want to write to G-code for circle with 4 hole in 4 side of circle. i must use G81.but I do not know how start it and what GCode is need.
    in fact a circle with 4 small circle inside it around 4 side.
    please help me.
    Jan 2009
    39
    G81 for circles?
    If you want to use G81, I take that you are drilling these circles and not
    interpolating these circles. The common G81 line requires:
    Z= depth
    R= reference plane
    f= feed rate
    But if you are interpolating these circles, you would want to use G3 to climb mill and G2 to conventional mill. And in order to help you any further I would need a little more information, than a circle with four circles inside it. Good Luck :cheers:
    Jul 2005
    12177
    Give use a drawing.
    Apr 2006
    3206
    Quote Originally Posted by Geof View Post
    Give use a drawing.
    The part may be a standard centrifuge mount........
    Not to be disparaging, but your talents may be wasted here, judging from the 3 months of posts by this guy. I'm all for helping newbies, but there's a whole lot of homework that isn't being done.
  1. TCC crash during pocket milling, polyline inside circle
    By StephanWenger in forum Uncategorised CAM Discussion
    Last Post: 12-02-2010, 03:36 PM
  2. inside circle cutting problem
    By glenthemann in forum G-Code Programing
    Last Post: 12-08-2009, 11:00 PM
  3. Gcode for circle
    By Chrille86 in forum G-Code Programing
    Last Post: 04-20-2009, 02:42 AM
  4. cut circle
    By bbrown2005 in forum Mach Wizards, Macros, & Addons
    Last Post: 02-05-2009, 01:41 AM
  5. circle
    By AngelT in forum Mach Mill
    Last Post: 06-30-2008, 02:59 PM
