Eureka!
I have finally made my first cuts. I have cut a square 100mmx120mm but it is exactly 1mm out all round.
The lead screw is 10 tpi, guide rails from igus. Hobbycnc board + motors.
Running acad, sheetcam, and mach2. The angles are perfect 90deg. the bit diameter is set correctly with outside offset.
Where could the problem be?
What should I check first and what sort of accuracy are other people getting?
