586,110 active members*
3,366 visitors online*
    Aug 2007
    50
    Centriod Giving error message
    Our Centriod is giving a "NO INPUT SIGNAL" error on startup, then screen goes black. She beeps, but I couldnt tell you what that means. open console and al the fans are on. Any advice???
    Mill is a M400S.
    Feb 2008
    280
    "No input signal" is typically the sort of thing the LCD monitor says when it is powered up, but it is not receiving any VGA signal from the computer. This usually means either that the computer did not begin to boot, or that the VGA cable from the computer to the LCD panel is loose or disconnected.
    Is the CPU fan on the Celeron or AMD processor (upper center of the motherboard) running?
    If you wait a couple minutes, do any lights in the jog panel (other than the spindle 100% and CW lights) come on? At that point, if you release the emergency stop, can you switch to Continuous jog mode and jog the axes around?
    If you can do those things, then it is just a display problem: probably a loose VGA connection.
    If the other jog panel LEDs never come on, and you can't jog, then the computer is not booting. In that case it is probably a motherboard issue, though it could just be the MATX power supply in the console. The power supply is less likely in your case, if the console fans keep running, but it is not out of the question.
  1. Error message CR1 etc.
    By NPI in forum Bridgeport / Hardinge Mills
    Last Post: 09-25-2010, 03:34 AM
  2. Replies: 5
    Last Post: 07-20-2010, 10:12 AM
  3. How do I fix this error message?
    By Patt66 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-09-2010, 07:22 PM
  4. Error Message
    By Mastercam User in forum Mastercam
    Last Post: 05-10-2008, 04:31 PM
  5. G83 error message
    By HBFixedGear in forum Fadal
    Last Post: 01-30-2007, 04:42 PM
