586,103 active members*
2,836 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Huanyang Chinese VFD settings and manual here!
Page 21 of 41 11192021222331
Results 401 to 420 of 808
  1. #401
    15362
    Re: Huanyang Chinese VFD settings and manual here!
    Quote Originally Posted by Azalin View Post
    By the way mactec54,
    The manual that came with my Huanyang as a parameter set for frequency skipping. It allows you to setup multiple frequency ranges. I don't remember the parameter numbers but let me know if you want them.
    I have the Skip Frequency Parameters, what I meant was not all the cheaper Drives have these Parameters to set, but what you are seeing should not be happening at 50Hz it should be smooth and quiet just as it is at 20Hz
    Your motor is very noisy at 50Hz it should be quiet at those settings, something is not set correct or the VFD is doing a really bad job, I don't think you would want a 6 pole motor, it would run too slow for your need
    Swap the output wires around, it may run in reverse, of what you want, but sometimes this can have an effect on a motor driven by a VFD
    Do you have good Grounding, motor to the VFD and Input power supply to the VFD
    Mactec54
  2. #402
    Mar 2014
    1131
    Yes, I swapped the wires. The cable from VFD to the motor is 4x2.5mm^2 shielded. Grounding is as as it should be.
    As I said I'll try my other VFD and see how it works with the motor. I don't know what else I can try.
  3. #403
    Mar 2014
    1131
    Look, I have a walking motor. No need to walk it twice a day.
  4. #404
    Mar 2014
    1131
    New motor. Works fine.
  5. #405
    15362
    You can take it up to 80Hz if it is happy at that go up to 100Hz
    Mactec54
  6. #406
    Dec 2014
    46
    I have been having the Huanyang blues,
    I have tried for two days to get the VFD to work with Mach3 no luck.
    Now I am trying to reset the factory settings I have tried several time to set PD0013 to 8 and factory setting won't restore
    Any help is appreciated
  7. #407
    Mar 2014
    1131
    Factory reset is PD013 = 01 on some versions.
  8. #408
    Dec 2014
    46
    Thanks Got it reset, it now can control with the panel arrow keys but not the pot on the panel any advice on the pot?
  9. #409
    Make sure the jumper is on pins 2-3.
    I wouldn't recommend running with the default parameters, unless you are 100% certain that they are correct for your spindle.
  10. #410
    Sep 2017
    8
    Hello,
    I receive my VFD and spindle few days ago and I have some problem to set it up.
    All wire have been check twice but when I put more than 100Hz, the spindle stop and and I have the following error message : E.LU.A
    According to manual, it's a low voltage problem but no idea where it could from.
    VFD is a HuanYang HY02D223B (2.2KW) and the spindle is HuanJiang 0.8KW water cooled.
    Does someone has any idea of the problem?
  11. #411
    15362
    Quote Originally Posted by davels View Post
    Hello,
    What terminals do you have wired for the input power supply to the VFD, and have you checked the Ground / Earth wire connection in the spindle motor ( Pin 4 )
    Mactec54
  12. #412
    Sep 2017
    8
    I wired R & T (I'm in Belgium, 240V). How can I check the Earth? I wired Earth to VFD and VFD to spindle. (See picture below)
  13. #413
    15362
    Your Hot wire ( Phase ) is Brown if this is the case then your Brown wire needs to be on the ( R Terminal ) and the Blue wire ( Null ) on the T terminal
    You check the spindle Earth wire, with a meter, check the Pin 4 to the Body of the Spindle, if this is not connected it also needs connecting inside the cap so the spindle is Earthed
    Mactec54
  14. #414
    Sep 2017
    8
    I try to switch wire but it doesn't change anything.
    Well, I have try to check Earth with a multimeter but not sure I did it well. On the multimeter, I have to set V-... and not ~, it's right?
  15. #415
    15362
    No it most likely did not change anything, but this is the correct way to have it wired, disconnect the spindle and see if you still get a low voltage Fault
    What parameters do you have set in the VFD Drive
    Yes you use your multimeter, and do a continuity check
    Mactec54
  16. #416
    Sep 2017
    8
    The seller ask me to set the following parameters :
    • PD005 = 400
    • PD004 = 400
    • PD003 = 400
    • PD072 = 400
    • PD144 = 3000
    As the VFD is 2.2KW and spindle is 0.8KW, don't I have to set it in the VFD?
    I'm sorry but my knowledge in electricity is near zero.. :/
    So I check the ground between Pin 4 and the body spindle in direct current. I got random numbers changing all the time. But is it direct or alternating ?
  17. #417
    15362
    • PD005 = 400
    • PD004 = 400
    • PD003 = 400
    • PD072 = 400
    • PD144 = 3000
    The best way for you to see how to use your multimeter for continuity test is YouTube
    Ok there are more parameters that need to set, this list will help, what they gave you are some of the main important Parameters
    Huanyang Mactec54
    PD000=0 for Parameter unlock ( 1 ) for Parameter Lock
    PD001=0 (1 For Remote Control)
    PD002=0 ( 1 For 0-10v Terminal Control or Remote Trim Pot Control ) ( J1 Also Needs to be set for Terminal Control )
    PD003=400
    PD004=400
    PD005=400
    PD007=20
    PD008=220 (Motor Rated Voltage )
    PD009=15
    PD010=8
    PD011=120 ( 100 Minimum Setting with Quality VFD, 120 is Safe)
    PD13= 08 is for Factory reset, Only use this to set VFD to Factory Default Settings
    PD014 Acceleration=12 ( Adjust to suit)
    PD015 Deceleration=12 (Adjust to suit)
    ( PD15 is ignored IF PD26=1 Then the Spindle will Coast to a Stop)
    PD141=220 ( Motor Rated Voltage )
    PD142= 4 ( Motor Amp Rating ) " Check your Spindle Motor Rated Amps that's What this Should Be Set To "
    PD143=2 ( Motor Number of Poles)
    PD144=3000 (Max Motor RPM) =3,000= (24,000)
    PD70=0 ( This may need to be set to 1 if Control Voltage is 0-5v )
    PD72=400
    PD73=120 ( 100 Minimum Setting )
    Mactec54
  18. #418
    Sep 2017
    8
    Huanyang Mactec54
    PD72=400
    I just set all these parameters but nothing change. The spindle start faster but this time stop earlier too.
    I have check continuity between ground and spindle body but not beep. Is it normal?
  19. #419
    15362
    Did you try just powering up the VFD without the spindle connected ???
    Does it do the same with the Spindle Disconnected ???
    Then check the spindle wiring next, ( U V W Connection to Spindle Connection ) from VFD to the Spindle, U to Pin 1 V to Pin 2 and W to Pin 3 You can check these by using the ( Beep on your multimeter,) With the Power Off
    If there is no beep then it has no Earth connection, this needs to be connected, inside the spindle cap a photo of what is needed, this won't solve the Low Voltage Fault But this needs to be connected
    Attached Thumbnails Attached Thumbnails Ground Wire -2.jpg   Spindle Wiring VFD to Spindle Plug.PNG
    Mactec54
  20. #420
    Sep 2017
    8
    I just try now and with the spindle disconnected the VFD don't stop. I don't have any error message even at 400Hz.
    Wiring is ok, I check it before several times. With the beep too to be certain.
    I had also check all the male pin of the spindle with the beep but nothing work. I'm not very comfortable to open the spindle as it's new :drowning:
    Edit : your second picture show U to R3 and W to R1, is it correct? You write U to Pin 1 and W to Pin 3 (as it's wired currently on my spindle)
  1. Car hoist 3phase settings on huanyang vfd
    By pietskiet in forum Spindles / VFD
    Last Post: 10-21-2019, 10:04 AM
  2. Replies: 4
    Last Post: 02-16-2017, 05:42 AM
  3. Huanyang SL-240EE Manual (SL Series Manual for Vector VFD)
    By Cogolith in forum Phase Converters
    Last Post: 05-24-2016, 04:19 AM
  4. Huanyang inverter PD settings
    By jamriggsy in forum Phase Converters
    Last Post: 03-15-2013, 04:54 PM
  5. Huanyang 2.2kw VFD, 0-10v 3600rpm settings?
    By EmeraldIsleforg in forum Phase Converters
    Last Post: 09-23-2012, 03:00 PM
