586,096 active members*
3,713 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Huanyang Chinese VFD settings and manual here!
Page 22 of 41 12202122232432
Results 421 to 440 of 808
  1. #421
    15362
    Re: Huanyang Chinese VFD settings and manual here!
    Quote Originally Posted by davels View Post
    I just try now and with the spindle disconnected the VFD don't stop. I don't have any error message even at 400Hz.
    Wiring is ok, I check it before several times. With the beep too to be certain.
    I had also check all the male pin of the spindle with the beep but nothing work. I'm not very comfortable to open the spindle as it's new :drowning:
    Edit : your second picture show U to R3 and W to R1, is it correct? You write U to Pin 1 and W to Pin 3 (as it's wired currently on my spindle)
    Ok so it seems that the spindle may be the problem, there is a different test for you to do not using the beep, you have to select Ohms to measure the spindle only
    Measure with Ohms setting, at the Spindle Plug ( Power OFF )
    Pin 1 to Pin 2=
    Pin 2 to Pin 3=
    Pin 3 to Pin 1=
    Then each Pin to Earth which in you case will be the Spindle body, as your Pin 4 Earth is not connected
    Yes that photo that I posted is for a different spindle, but may still apply to yours, so worth a try, but it most likely won't change anything
    90 % of these spindles, the users have to fix the Earth connection in the spindle plug, you could of course, just to try use the Ground wire that you have going to the spindle, attach it to the spindle Body, ( Just for a Test )
    Have you used shielded Cable from the VFD to the Spindle???
    Mactec54
  2. #422
    Sep 2017
    8
    Pin 1 to Pin 2=
    Pin 2 to Pin 3=
    Pin 3 to Pin 1=
    All Pin to Pin (1, 2, 3) give 4.2 Ohms. And Pin 1, 2, 3 to Pin 4 give no result.
    Indeed change the wire doesn't change anything.
    I have try to ground the spindle body with a cable from the ground VFD to the spindle body but it doesn't change anything neither.
    No, the cable is not shielded, could it be the problem?
    Edit : I have remove the 4 screws on top for the spindle but I can't remove the top. Is it glue or something like that ?
  3. #423
    15362
    Put the 4 screws back in add a metal spacer under one of the screws then attach you Earth wire to that screw, you could use a piece of threaded rod then add a spacer a nut then a washer, add your Earth wire and another washer and nut, this will save you taking the top off, yes some are stuck on with some kind of sealer to prevent any water leaks, You can use a longer screw like what is already there with a spacer, washers and nuts, or what I have posted in the photo
    When using your meter with the Ohms setting, what is the reading when you just touch the 2 probes together, as the spindle readings seem to be to high, but could be fine, check again at the Spindle Plug with the cable disconnected
    With out a shielded cable, yes this can cause this problem, the shield also has to be correctly Earthed or it will cause problems also, But adding a Earth wire also may get it running, then look at the Shielded cable, as this is a requirement
    It seems that your spindle is Bad with the high reading, and none of these things will fix that, contact the seller for a new spindle, what was the slowest speed that you ran the spindle at, slow running will damage these spindles
    Mactec54
  4. #424
    Sep 2007
    I got the HY01D523B 220v and 1.5kw spindle. Had some struggle getting the VI speed adjustment working, so did a factory reset. Now the spindle does not run properly evem following several setup suggestion on this page.
    What happen is that the spindle start up really slow and do not gain much speed before I get some error code.
    Guessing one of the menu setup are not correct. It worked perfectly before the factory default and the wiring are the same.
    Anyone got a tip?
  5. #425
    15362
    Quote Originally Posted by IBICO View Post
    Anyone got a tip?
    You have some parameter that is not set correct, a slow start up is a bad thing, this can damage the Spindle and VFD, what parameters have you set
    Mactec54
  6. #426
    Sep 2007
    That is just stating the obvious. I know I got some parameter wrong, but even after following some of the setup here, and setting the motor parameter from my motor correct I still get this slow start.
    One thing I notice is that my motor got 8amp stamped on it, but the VFD only could set 7amp as maximum. But if that is the problem, then the motor should not have worked before either. 2pole is set, 220v and other setup.
    I guess I just have to do a factory reset again and try all over. Would be my third time with factory reset and setting all the parameters
    The motor worked perfectly before I did a factory reset of the VFD
  7. #427
    15362
    You never want to do a Factory Reset unless there is something very wrong with the VFD
    For the 1.5 Kw it should only have a max of 7 amps, Here is what you have to set, you will have a frequency Parameter set in correct, they need to match this list
    Huanyang Mactec54
    PD000=0 for Parameter unlock ( 1 ) for Parameter Lock
    PD001=0 (1 For Remote Control)
    PD002=0 ( 1 For 0-10v Terminal Control or Remote Trim Pot Control )
    ( J1 Also Needs to be set for Terminal Control )
    PD003=400
    PD004=400
    PD005=400
    PD007=20
    PD008=220 (Motor Rated Voltage)
    PD009=15
    PD010=8
    PD011=120 ( 100 Minimum Setting with Quality VFD, 120 is Safe)
    PD13= 08 is for Factory reset, Only use this to set VFD to Factory Default Settings
    PD014 Acceleration=12 ( Adjust to suit)
    PD015 Deceleration=12 (Adjust to suit)
    ( PD15 is ignored IF PD26=1 Then the Spindle will Coast to a Stop)
    PD141=220 ( Motor Rated Voltage )
    PD142=7 ( Motor Max Amps for 1.5Kw Spindle)
    PD143=2 ( Motor Number of Poles)
    PD144=3000 (Max Motor RPM) =3,000= (24,000)
    PD70=0 ( This may need to be set to 1 if Control Voltage is 0-5v )
    PD72=400
    PD73=120 ( 100 Minimum Setting )
    Mactec54
  8. #428
    Sep 2017
    4
    greetings. I have to say that this thread (and forum) is awesome and very helful.
    I am building a litle cnc with aprox 450mmx450 of work area. My goal is work with aluminum. I am half the way and now is the turn of the spindle/vfd.
    As far as I know with a 800 w spindle i have enough power. The cnc is not big and in the drawings the 800w spindle (65x180mm) looks more equilibrated than the 1.5 kw spindle (80x200mm)
    I am thinking in purchase the 800 w watercooled spindle and a huan yang vfd. In ebay i can purchase the 1.5, 2.2 or 3 kw vfd. The fact is that the price of the 3 kw vfd is only 15 euros more than the 1.5 kw
    I am thinking in buying the 3 kw or 2.2 kw vfd, and if i see that with the 800 w i am short of power keep the vdf and purchase a 1.5 spindle.
    I supose that is better to have this extra power and this way i can use the bigger vfd if i increase the spindle size.
    So, please from your point of view witch vfd shouls i buy to follow this strategy 2.2 kw or 3 kw?
    MAke all this sense? Thanks in advance
  9. #429
    Nov 2013
    65
    Quote Originally Posted by Sergio76 View Post
    I have the 2.2kw water cooled spindle and I'm very happy with it, it's almost 5 years since I use it daily and it's still running nice. I don't know why but until I added an mist emulsion system to my router, I wasn't able to easily mill aluminum, but after purchasing a spray like cheap system, wow .. that's the only thing I could say Also the milling strategy helped (trochoidal plugin for cambam) https://www.youtube.com/watch?v=f8ZTBkfLXOQ
    So, build your router so the table can be waterproof, and somewhere at the back make some groves or holes to collect the emulsion inside a tank, to recirculate it. This was big for me regarding milling aluminum !!!! Realy really important. I tried only with compressed air but it didn't work unfortunately.
    Good luck.
  10. #430
    Sep 2017
    4
    Quote Originally Posted by ovisopa View Post
    Good luck.
    I apreciate the feedback. It semms a quite larger machine than the one that i'm building though. I am limited in space.
    Reading this thread i realized that the huan yang vfd are reliable and cheap, strong combination.
    If anyone can confirm that there are no issues, or even, is better to have a 3 kw vfd with an 0.8-1.5 kw spindle would be nice.
    My intuition is pointing this way but a qualified/experienced opinion would be very helpful. Thanks!!
  11. #431
    Nov 2013
    65
    @Sergio76 My machine has a work area of 880 x 600mm, the VFD and spindle are both 2.2kw but if you want a 3kw VFD and a smaller spindle I don't see what could be wrong (other than spending extra money for the bigger VFD) I'm sure it will work, but why do you want to get a VFD with double the power of the spindle? Are you planing to upgrade your spindle in the feature ?
    I posted to this thread a few months ago asking guys if they know what setting I must change to the VFD, to be able again to set the RPM to 24k, since I replaced the LCD module, in the past I had an LCD with buttons only, so changing the RPM always needed multiple presses on thos buttons, I purchased an potentiometer LCD module, it's much easier now to change the RPM, but since I mounted this module, the maximum RPM is ~12k , Anyone knows what setting I should change to be able to set the RPM to 24k ?
    PS. I'm almost everytime milling at around 9.5k RPM, but there are times when I need a higher RPM
  12. #432
    Sep 2017
    4
    Yes that's the idea.To be able of upgrading the spindle in case that i need more power. I know that for aluminum you should go on high rpm, but i don't know how is going to perform the 800 w on lower RPM for other materials.
    I don't wanna over stress the whole machine putting a bigger spindle if i can work with a smaller one.
    Good Luck with this LCD!
  13. #433
    Nov 2013
    65
    I don;t know how high RPM are you thinking to use, I was milling with 12k - 14k in that movie. Aluminum is not that easy to mill because it sticks to your endmills, if the RPM is too high it will stick very rapidly and brake the endmill in seconds.
    My suggestion is to go for a 1.5kw spindle, is that much bigger than the 800w one ? Don't pay for a bigger VFD, get from the begginign a bigger Spindle, and a matched VFD and you will find the feed and speeds that work best for what you got. If you mill using small endmills, like 4mm I think any spindle will be good, you need more power when milling with larger end mills, or with a higher DOC .
    As I said in my other posts, design your router table so it can handle spraying emulsion while cutting, it will help you a lot when milling aluminum. I mill most of the time policarbonate from 1 to 15mm thick, also MDF 22mm thick, aluminum from 6 to 40mm thick, and now on a new metal mill (Tormach) I mill steel parts.
  14. #434
    15362
    The smaller spindle will work 800w but you will be taking very light cuts, the more power the spindle has the better it will cut Aluminum, 3Kw VFD is the right size for a 2.2Kw spindle running on single phase power
    A VFD should always have a higher rating when running on single phase power 1 Hp to 2Hp higher rating is the recommended norm
    You won't over stress your machine with a larger spindle, you build your machine as rigid as you can, if your machine build is not strong enough then it will fail even with the small 800w spindle, if you intend to cut Aluminum
    Mactec54
  15. #435
    Sep 2017
    4
    Thanks ovisopa and mactec54 for your answers, you helped me a lot. I will finally go to 1.5 kw spindle and 3 kw vfd
  16. #436
    Apr 2015
    113
    I have a 1.5kw spindle + VFD. Ive cut 1.5mm aluminum per pass. The spindle will stall if you do a wrong entry. Next machine is definitely 2.2 or 3kw. Dont think you actually need a bigger VFD anyways.
    Luthier/Woodworker/Machinist in NS, Canada.
  17. #437
    Nov 2013
    65
    Stall ?? With what end mill diameter and what RPM ? As with the wrong settings and end mill you can stall a 3kw spindle too. When I was milling I was using very few Watts even if the depth of cut was 7 timers higher than yours (10mm DOC)
    Quote Originally Posted by jahnj0584 View Post
    I started up with similar DOC, but after I started using a mist system and trochoidal milling plugin for CamBam, to avoid having the end mill 100% engaged (I tried to avoid slot milling, with low DOC, like 1.5mm I could do slots, but with higher DOC I didn't tried) I could go and mill with a much higher DOC, 10mm DOC is also good as you use the whole end mill cutting side, not just the first 1.5mm of the blade!
    If Sergio will use end mills 4mm, 6mm or even 8 mm with caution I'm sure the 1.5kw spindle will handle cutting through aluminum, it's all about finding the right settings. I found it more difficult to make holes, as for drills the RPM should be low, but at low RPM those spindles don't have any power.
  18. #438
    Apr 2015
    113
    Ive stalled with a 1/8 single flute pecking too hard, a 30mm mortise bit when leveling my MDF spoiler, and even just with my 6mm EM 10mm deep in hard wood. All of these at 16k, 14k for the 30mm bit.
    Yes Im aware of adaptive clearing, but for sheet goods a ramped contour is always faster then adaptively clearing out 20 linear inches at a 0.02 pass width.
  19. #439
    You spindle is either faulty, or your settings are incorrect. No way you should be able to stall your spindle with an 1/8" bit.
  20. #440
    Sep 2017
    8
    Hello mactec54, I come back to you with my spindle problem. The seller send me a new VFD and everything is running nice now. I still have to connect the ground on the spindle throw the screw like you send the picture. Thanks a lot for your help!
    I also buy a shielded cable, I should receive it next week. Does the shield has to be connected to the ground on VFD and Spindle?
    Thx, David
  1. Car hoist 3phase settings on huanyang vfd
    By pietskiet in forum Spindles / VFD
    Last Post: 10-21-2019, 10:04 AM
  2. Replies: 4
    Last Post: 02-16-2017, 05:42 AM
  3. Huanyang SL-240EE Manual (SL Series Manual for Vector VFD)
    By Cogolith in forum Phase Converters
    Last Post: 05-24-2016, 04:19 AM
  4. Huanyang inverter PD settings
    By jamriggsy in forum Phase Converters
    Last Post: 03-15-2013, 04:54 PM
  5. Huanyang 2.2kw VFD, 0-10v 3600rpm settings?
    By EmeraldIsleforg in forum Phase Converters
    Last Post: 09-23-2012, 03:00 PM
