586,075 active members*
3,999 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Huanyang Chinese VFD settings and manual here!
Page 39 of 41 293738394041
Results 761 to 780 of 808
  1. #761
    Aug 2021
    4
    Re: Huanyang Chinese VFD settings and manual here!
    Update. I punted. Went back to my old 1.5kW setup and it's working perfectly. Thanks for your help though! I really appreciate the effort.
  2. #762
    do you think you can help me with my vfd settings
    https://www.cnczone.com/forums/spind...ml#post2468956
  3. #763
    Feb 2011
    138
    Hi to all,
    I also have this VFD (HY02D223B) for 2.2kw motor, question is, can be water pump connected to relay inside of VFD? Maybe some input? Which "code" shoud be adjusted?
    Thanks in adwance,
  4. #764
    Jan 2007
    31
    But why do you want to do this, the pump could be running continously without causing an issue.
  5. #765
    Feb 2011
    138
    I know but it shoud be turned on/off somehaw, and I don't want an extra switch. Untill now I have that throu software, but now is luck of free output's...
    So, looking for some soution and it will be nice if VFD will do that for me.
  6. #766
    15362
    Quote Originally Posted by maki View Post
    Hi to all,
    Thanks in adwance,
    Yes, you can, and a lot do this just make sure the Amp rating of the pump is less than the max rating of the built in VFD Drive relay.
    Mactec54
  7. #767
    15362
    Just check with a meter to see which relay connection is N/O and that it closes when you start the VFD Drive, this should be FC to FB, Parameter PD052=01 to change for these Relays to be working as a Relay, Default is 02 which may work also but this is normally for fault detection, pump must be less than 3Amps
    Mactec54
  8. #768
    Feb 2011
    138
    Thank you mactec54, I'll check the pump, it comes with VF as bundle and is submurssable I think is 75W.....kind a akvarium pump
  9. #769
    Feb 2011
    138
    I have take a look to the manual of VFD, and under"PD052"= 0-invalid, 1-Run, 2-Zerro speed, 3-Fault indication, 4-Braking indication, 5-Set Frequency reach, 6-In Accel, 7-In Decel, 8-Arbitrary Frequency 1 reach, 9-Arbitrary Frequency 2 reach.
    My question is if I put it to Nr.:5, will turn ON WHEN rpm is reached? Or just put it on Nr.:1 ....just my toughts...
  10. #770
    15362
    No, you want it on as soon as the spindle starts
    You need to set it PD052=01 as I said in what I posted
    Mactec54
  11. #771
    Feb 2011
    138
    Thank you mactec54, will do that as you suggested.
  12. #772
    Dec 2013
    I'm hoping this thread is still viewed and someone can help.
    I have a HY inverter Model 02D223B and a 2.2KW 220v 400hz spindle
    The spindle and VFD were running ok with a XHC MKX-V Mach3 Breakout Board and Mach3 but had issues with the stepper motors so i have reconfigured the CNC with a CSMIO IP-S and SIM CNC software and have now eliminated that issue but after re wiring the VFD to the new controller i'm now having issues with it and the VFD. Unfortunately en-labs are not the best for communication or help with set up issues
    The VFD works fine via the operator control panel and speed can be controlled but when trying to control it via the CSMIO IP-S i get nothing
    The VDF parameters are as follows
    PD000=0
    PD001=1
    PD002=1
    PD003=400
    PD004=400
    PD005=400
    PD007=20
    PD008=220
    PD009=15
    PD010=8
    PD011=120
    PD014 Accel=10
    PD015 Deccl=10
    PD070=0
    PD072=400
    PD073=120
    PD141=220
    PD142=11
    PD143=2
    PD144=3000
    I have checked all other parameters against the manual are all ok/ factory settings
    The above settings seem to be correct as per previous posts. I have wired the VFD as per diagram provided by en-labs whiuch is below ( i now know Reverse is not needed and can be dangerous and willl remove after posting this)
Name:	VFD Wiring.jpg
    the VFD is wired
    VI 0-10v Analog
    ACM - GND
    FOR - Digital output 1 (24v supply)
    REV - Digtail outout 3 (24v supply)
    DCM - 0v supply
    FA & FB is wired into the CSMIO IP-S and the spindle fault relay is working ok
    The Software and controller i think are working ok as when i turn the spindle on via the controller i get 0-10v across VI and ACM which can be controlled, the query i have is that i get 22.5v across either FOR or REV and DCM when in idle or estop state but when i switch the spindle on the controller the voltage increases to 24v. I'm waiting to here back from en labs to see if this is correct.
  13. #773
    Jun 2012
    153
    Where is this 24V coming from ? I'm not sure the digital inputs will like 24V.
    CSMIO IP-S show 24V as an example that does not mean it requires 24V. It says output driver is VNQ860
    Each group is controlled by specialized
    chip VNQ860. These chips work in PNP
    logic, thus the active state is a high state
    (+24V).
    VNQ860 Datasheet pdf - QUAD CHANNEL HIGH SIDE DRIVER - SGS Thomson Microelectronics
    VNQ860 can work from 5.5 to 36V supply. This should match what you need to send to the VFD.
    The VFD manual does not seem to specify the voltage of the input pins but against DCOM is says it is the ground for "digital and control signals, 12v power, EV, IPV, P24 ground".
    Chinese clarity of course but possibly means they need 12VDC signals.
    What tension was the MACH3 board sending ?
    Do you have a potentiometer control on your VFD or are you using the programmable speed control ?
  14. #774
    Dec 2013
    thanks for the reply
    yes i have a potentiometer on my VFD and works perfectly in operator mode PD001 - 0
    On the previous controllor the digital output to the VFD was also 24v but because this worked ok i never measured active and inactive state so unsure if this was also the case.
    Each set of digital ouputs are optoisolated and require their own power supply, en-labs have stated for this to be 24V
    manual_csmioip-s_en_v3 (1).pdf
    I have expanded the diagram to show this
    simcnc-csmioip-s-hy VFD.pdf
  15. #775
    Jun 2012
    153
    when I looked at the CSMIO IP-S manual I did not see a specification of 24V , this seemed to indicated in wiring diagrams , often in brackets. From the chip datasheet we see this is NOT a required voltage. However, if you previous set up was using 24V apparently that is safe. I made my own hardware and used 12V for control lines .
    In a heavy industrial context with a lot of RFI, 24V will give more noise immunity.
    I'll try to dig out my PCB design for use of these lines.
    I would suggest taking the e-stop out of the equation until you track this down. Also you leave the inputs floating when relays not activated and say you get 24V when activated and in this case they should be grounded. That looks like a wiring fault unless I misunderstand what you described there.
  16. #776
    Jun 2012
    153
    Mine has a jumper you need to move if using Vin as the speed control.
  17. #777
    15362
    Quote Originally Posted by shaun348 View Post
    PD000=0
    PD001=1
    PD002=1
    PD003=400
    PD004=400
    PD005=400
    PD007=20
    PD008=220
    PD009=15
    PD010=8
    PD011=120
    PD014 Accel=10
    PD015 Deccl=10
    PD070=0
    PD072=400
    PD073=120
    PD141=220
    PD142=11
    PD143=2
    PD144=3000
    the VFD is wired
    VI 0-10v Analog
    ACM - GND
    DCM - 0v supply
    Normally on this VFD Drive it is best to use a Relay to turn it 0N/0FF the control 24v would be used to activate a Relay input there is no Voltage required to switch FOR and DCM
    So, if your control has a Rely output use that, to control the FOR / DCM terminals= 0N/0ff this circuit should have NO voltage this is just a switch between FOR / DCM
    Mactec54
  18. #778
    Hi Shaun,
    I created another scheme for you, that is, I expanded the one I sent you previously. I hope it helps this time. Also, pay attention to the parameter numbers that I indicate because they are crucial.
    https://en.cs-lab.eu/wp-content/uplo...vfd-simcnc.jpg
    Regards,
    WT
    CS-Lab Team
  19. #779
    15362
    Quote Originally Posted by CNC support View Post
    Hi Shaun,
    Regards,
    WT
    CS-Lab Team
    That looks to be correct and the normal way to do it, you don't use Reverse with your spindle so that would eliminate that part of it.
    Mactec54
  20. #780
    Apr 2022
    16
    Quote Originally Posted by Apocalipsis View Post
    Yo Christian, thanks for your quick answer, so can you please help me with this conf- ?? i have read the whole manual and still i think im doing it ok.
    Which are the parameters on the VFD that i should check?
    Thanks in advance
    Edit 1. Yes it looks like the freq. on the parameter 4 its on 50 HZ, but it cannot be changed to a higher one.
    Edit 2. Now taking a better inspection Pd003 (according the manual MAIN FREQUENCY) remains on 50Hz, cannot be changed to a higher freq im assuming that this is the input frequency. , Pd004 now i set it on 60Hz but i read somewhere that is better to put a higher value (400 was the recommended frequency). Is this safe for the VFD? Now Pd005 must be 60Hz or should i also changed it to 400 Hz?
    I understand this thread is almost 10 years old, but I need to provide caution. DO NOT SET PD004 and PD005 TO 60!!!!!!!!!!! SET PD004 and PD005 to 400!!!! You will burn up your spindle! if you use 60!!!!!!!!!!!!!!!!!!!!!!!!!
  1. Car hoist 3phase settings on huanyang vfd
    By pietskiet in forum Spindles / VFD
    Last Post: 10-21-2019, 10:04 AM
  2. Replies: 4
    Last Post: 02-16-2017, 05:42 AM
  3. Huanyang SL-240EE Manual (SL Series Manual for Vector VFD)
    By Cogolith in forum Phase Converters
    Last Post: 05-24-2016, 04:19 AM
  4. Huanyang inverter PD settings
    By jamriggsy in forum Phase Converters
    Last Post: 03-15-2013, 04:54 PM
  5. Huanyang 2.2kw VFD, 0-10v 3600rpm settings?
    By EmeraldIsleforg in forum Phase Converters
    Last Post: 09-23-2012, 03:00 PM
