Is there a way to calibrate the input PWM range? For some reason my BOB is only outputting 8.8v at full speed and the vfd never gets up to full speed . Tach measured rpm matches displayed, by is significantly lower than called for by Mach 3. At 24k requested, 22500 is achieved. At 12k requested, 7500 is achieved.
Thanks for the links and the info MACTEC54. The manual they sent with mine was printed in 4 pt. type: kind of a cruel joke for these old eyes.
Any body know of an inexpensive water cooling system that will work well for my water cooled 2.2 KW Haunyang spindle? I've seen some on e-bay that might work. I'm just a newb trying to guess.
gb
I can't run the spindle from mach3, can help me?
Huanyang VFD and DDSM3-V5 motion board upload the manuals.
I think that in doing this I will be able to make thread, yes?
Was reading in an another topic I found on google with some settings beeing posted about torque on low speed. These settings work real good for me. Ofcourse only with watercooled spindles and I might be lucky with a good VFD?
Hi Guys
I am trying to figure out how to wire the speed control of the VFD to this BoB (leeuwing.nl) using MACH3, anybody have any idea?
The BoB manual says the following:
The analogue SPindle output will give you a 0-10V signal suitable for connectionto a variable speed drive. The GND must be connected and SIG is the 0-10V
signal. P0, PW, and P1 are the ‘low’ end, wiper and ‘high’ end of an external
override potentiometer, use a 10K linear potentiometer. The SW and SW are for
an external switch, this will disable the circuit when open and this connection
must be closed for the circuit to work.
TmanSA
It looks like you have it wired correct
Have you checked that you are getting 0-10v out of your Breakout Board, start your spindle in your control software & take it up/down measuring the output from your Breakout Board, if this is ok, then you need to look at your VFD parameter settings for when using 0-10v
Also check that the Relay is turning on when you turn the Spindle on
Mactec54
What you mean with "real good"? Having significally more torque? At what rpm you have been testing?
I'm suprised that no one has been doing more experiments with these settings, are everybody running their spindles at 24000rpm??.... After all if we change max freq. from default setting 50hz to 400hz, I guess also those intermediate settings have to be adjusted. At least I would like to get the best possible performance at little lower speeds like 8000-16000 rpm.
Advices needed, those v/f curves in the user manual are ...chinese.
If you have set your Parameters to the correct setting for your Spindle Motor, you can run your Spindle at what the manufacture recommends, 6,000 RPM is not uncommon for these spindles, for you to run yours at 8,000 RPM you would have to know what the minimum frequency setting is, or the minimum RPM is for your Spindle
The safest minimum frequency is 120 Hz for these VFD Drives, with a good quality VFD the minimum can be 100Hz & lower to suit the minimum RPM ( speed ) the manufactures recommend for the spindle being used
The default setting has nothing to do with your spindle, if you set or left it at the default settings, you will damage, sometimes smoke the VFD with your first try
The default settings that your VFD & most other VFD use, are used for standard 3 phase AC motors, not your high frequency, high speed spindles
Mactec54
Yes, I have set my minimum to 100hz and I can run it at 6000rpm (water cooled spindle) but I'd like to get more performance at intermediate speeds and I guess that it is uncorrect to leave PD006 = 2.5hz and PD009 a= 13v since they are factory default intermediate v/f curve points (where max is set at 50hz).
The curve is limited to 3 points, set by 6 parameters. Defaults are:
PD007=0.5 Minimum Frequency, PD010=8 Minimum Voltage (just a curve point, not effecting minimum frequency limit )
PD006=2.5 Intermediate Freq., PD009=13 Intermediate Voltage
PD005=50 Maximum Frequency, PD008=220 Maximum Voltage
...so when changing PD005 to 400Hz (at 220V), how should those intermediate values follow?
How you got that 55v at 100hz? Would like to understand the logics....
Anyway, the manual is giving me:
PD005 Max Operating Frequency 50.00~400.00 Hz (factory default 50.00)
PD006 Intermediate Frequency 0.01~400.00 Hz ( 2.50)
PD007 Min. Frequency 0.01~20.00 Hz (0.50)
PD008 Max. Voltage 0.1V— (220)
PD009 Intermediate Voltage 0.1V— (15)
PD010 Min. Voltage 0.1~50.0V (8)
PD011 Frequency Lower Limit 0.00~400.00 Hz (0.00)
*Min.Voltage Value = Intermediate Voltage Value/2
*The intermediate frequency is 2.5 for the system of 50Hz.
....with PD005 and PD011 I set my max and min limits (100-400) and PD006...PD010 are for V/F curve.
But why they propose intermediate frequency so low as 2.5Hz (15V) ?
Mactec54
kmin
The volt's to frequency, is a ratio, 220v divided by 400 Hz gives you the ratio of volts to frequency, once you know were you want to have your best performance from your motor you can then set the voltage by using this ratio, this voltage setting can be increased or lowered, depending on the motor quality, the higher you increase the voltage for a given frequency, the higher the current will be, setting this to high will smoke your motor
Mactec54
Thank's mactec54,
I do undestand the ratio but the tolerances are not clear to me. Nickgroen89 was happy with his intermediate point set as 36V/10Hz with same setup I have. So 6 times higher than ratio of 220V/400Hz!
Obviously at 100-120 Hz low limit that difference would be less, but significant anyway.
I think he was just playing with some numbers, with no knowledge of what the outcome would be
I did do some playing with numbers also & found that @ 100 Hz ( 6,000 RPM ) you can use up to a max of 40% increase in the voltage,55v to 77v but at 250 Hz ( 15,000 RPM ) the max increase can only be 12% 137.5v to 154v at 150 Hz it was a max of 20% 82.5v to 99v
The numbers that he is using is more than 650% increase, VFD drives mostly only have a max 150 % before they fault out, if he has this setting just for starting then it would only be active for the ramp up to speed time
For getting more torque PD145 can be adjusted, this is auto torque compensation, Default is 2% to a max of 10%
Mactec54
Ok, now the whole thing is clear to me.
By the way, if I'm trying Nickgroen's values on the curve, it's giving 78V at 100Hz and 150V at 250Hz, basically same you got playing with yours. Since he has min limit at 100 or 120Hz, it would be ok.
Do you know how that auto torque compensation is working?
Thank's a lot Mactec!!
kmin
I would not run, or do the settings that aggressive, they are an absolute Max, what you have to watch for is over saturation of the windings, which can happen very quickly with these aggressive settings, so aim for the middle between the minimum & max voltage, this would be a lot safer
The auto torque compensation, will give your spindle more torque to overcome, a sudden heavy cut, to help prevent the spindle from stalling
Mactec54
Ok, thank's!
