586,594 active members*
2,839 visitors online*
    Feb 2007
    314
    macro b local variable
    Does local variable are reset to null a the end of program? I think there is some prm related to variable but i don't know wich one. Fanuc 0M-D
    2932
    Here's the only information I can find on that (from the 0M-D Parameter Manual)
    Attached Thumbnails Attached Thumbnails 0M-D Macro Variables when Reset].jpg
    Jun 2008
    1511
    Some model Fanucs have a parameter for clearing them to null after M30 or reset and some do not. According the setting Dave has posted it is after reset but it says nothing about ending with M2 or end/rewind with M30. What you will probably have to do is run a program and try.
    #1=1
    M30---then try M2
    Do this with the parameter settings Dave gave you set both ways.
    Stevo
    Mar 2010
    Local variables get reset (set to vacant) on power down or by reset depending on the parameter. Most often the PMC ladder (machine tool builder) will create a reset on M02/M30. Therefore, M02/M30 may (or most often) will reset the local variables based on the parameter. The 0-MD parameter was given previously.
    The test provided will of course disclose all.
    Nov 2010
    Wink
    Only the lower # variables get reset. Try using #500. I've used it many times with no problem at all.
    Dan
  1. Mazak Fusion 640 Local Variable Display
    By ggborgen in forum Parametric Programing
    Last Post: 10-31-2010, 09:33 AM
  2. Macro Variable Lock
    By James L in forum Haas Mills
    Last Post: 07-23-2009, 02:29 PM
  3. local variables of a macro
    By sinha_nsit in forum Fanuc
    Last Post: 01-16-2008, 01:19 PM
  4. Macro variable example I programmed today.
    By theemudracer in forum G-Code Programing
    Last Post: 03-08-2007, 03:50 AM
  5. Macro variable for current tool diam ?
    By Shizzlemah in forum Fadal
    Last Post: 10-30-2006, 03:47 PM
