586,067 active members*
4,722 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > G540 spindle control problem
Results 1 to 9 of 9
    Nov 2010
    I know this has been covered in some detail in many other threads, but I haven't found anything describing the problem I'm having. I just rigged my x2 spindle to my g540. P1, P2, and P3 to ports 7,8,9. I can control the spindle in mach3, but it does not run smoothly. You can hear the rpm's fluctuate, and the spindle now stalls easily. I just stalled it while doing a .02" flycut in Al.
    My pwm settings are 50hz, 20%. Spindle pulley settings are 0-3000 rpm, 1:1. I've been advised that my problem is most likely due to the pwm setting, but I can't find any recommended values in the gecko literature. Please shed any light you can, thanks. :cheers:
    Minimum PWM should be 5% according to Pminmo.
    G540 VFD
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Nov 2010
    Hoss, you're a saint in a common man's shoes. One who, apparently, doesn't sleep. Thanks for the helpful reply.
    I got the 20% value from another thread, from a poster who was having similar problems. I kept getting a "pwm bumped to minimum setting" message. I had tried pminmo's .xml file but it failed to work. I revisited the problem in my current xml and it seems to be working correctly now, but I have to play with the settings every time I open up mach. For some reason it's not saving all of my settings, ie spindle pulley settings. Not a huge problem, just takes a few extra seconds upon startup.
    Nov 2010
    Hate to cry wolf, but my problem persists. It now runs smoother at low rpms, but when I increase them to what sounds to be half power (no tach to check exact range) it starts running unsteadily. 50hz, 5%. Any other ideas, Hoss?
    Nov 2009
    4415
    I do not understand the problems you are having but shouldnt that 50Hz be 60Hz in the US? Of course I could be way off.(chair)
    Quote Originally Posted by rewster View Post
    The pminmo settings have worked for other X2's but I checked the G540 XML,
    maybe they still just have it at some random default setting but their numbers are the opposite pmnimos,
    PWM base freq, 5, Minimum PWM 50%.
    On saving, do you have mach installed in the default directory?, if you make changes it should ask you if you want to save fixture.
    Hoss
    Nov 2010
    Quote Originally Posted by Fastest1 View Post
    Please enlighten me, why would this be? You could be right. I'm electrically incompetent.
    Hoss, I noticed that too but figured it was just a default. I will try swapping the values and see what happens. Also, what should my spindle motor tuning setting be? I have 2500 steps, 120 velocity and 4 acceleration....again, per the setting of another user.
    I was going to hook the pot back up just to be certain I don't have a power supply problem, but I didn't take note of which wires went where when I disconnected it. I guess I'll dig up a wiring diagram of the x2, if one exists. My roomate is an electrician and I'm having him double check the circuits in my shop. I have no reason to believe that my problem is in my power supply since everything ran fine before I wired up the vfd.
    Also, I disconnected all 3 P-wires but pminmo suggests leaving p1 and p3 connected. Could this have an effect?
    Thanks for the replies, keep 'em coming if you have any other ideas!
    Nov 2009
    4415
    60Hz is the US electrical standard. 50Hz is used in Europe and other places. However these are supply voltage parameters, regulating the speed of a motor can probably be done a few ways ( I have no knowledge in this area). I do know I have a VFD on a 3ph motor and it regulates the rpm by varying the output frequency, hence the name "variable frequency drive". I also run a drive for a DC motor called a Bardac 1600I but it has been so long since I looked at that project, I forgot how I got it to work originally. I sure hope I took a few notes! I am sure it will be obvious when I get back on that project. LOL
    Sep 2009
    139
    I'm thinking about getting the g540. Was wondering what sx2 you have. I got the little machine shop one. Does yours have the brushless motor? I'm somewhat electronics incompetent.lol
  1. G540 Spindle Control Working
    By whitehedr in forum Benchtop Machines
    Last Post: 06-30-2018, 12:51 AM
  2. Has Anyone used G540 to control spindle speed on the X2?
    By Waldermac in forum Benchtop Machines
    Last Post: 02-08-2018, 03:46 PM
  3. G540 Spindle Control for the X3 / Guide
    By Jeff Davis in forum Benchtop Machines
    Last Post: 09-02-2010, 09:53 PM
  4. Is it possible? (G540 spindle control)
    By fretsman in forum Gecko Drives
    Last Post: 10-14-2009, 12:27 AM
  5. Spindle Control Through G540
    By john1285 in forum Gecko Drives
    Last Post: 09-30-2009, 04:26 PM
