Hi Guys
Just trying to get my head around MDI-ing a LBL into a prog, I have written a contour, but now I want to repeat and incrementaly put a cut on in Z till I have reached total depth I know it's easy but Help!!!
Hi Guys
LBL 1
IZ-.05
[contour]
LBL 0
CALL LBL 1 REP 5
remember you can only call a label with multiple reps once, so you may have to make a work around. If you try it will blow right through the LBL 0, so it is wise to put the labels at the end and put a stop below them. Get in the habit of putting all Z moves outside of the label, allowing you to change all sorts of things when needed.
Thanks Gus for the help
Cheers
Merry Christmas and prosperous new year
