586,080 active members*
3,485 visitors online*
IndustryArena Forum > CAM Software > MadCAM > Code moving to z position before xy
    Oct 2010
    Unhappy Code moving to z position before xy
    Hi All,
    Another question when running my MadCam code in Mach 3 it seems to drop to the z0 height then travel to the xy start position.
    Obviously this is not ideal, especially if the piece to be cut is not perfectly level.... I don't really understand code, but is the piece of code highlighted red below telling it to go to z0 before it moves to the correct xy position?
    Maybe I'm totally wrong and the code is correct but if not where do change this setting so it travels safely?
    Thanks in advance,
    Richard
    G00 G49 G40.1 G17 G80 G50 G90 G64
    G21
    (FLAT_END_1.6mm)
    M6 T1
    M03 S16000
    G01Z0.000
    G00X50.362Y5.199
    Z3.000
    G01Z2.230 F1000
    X50.100Y5.199Z-0.770 F3000
    X89.010Y5.200Z-0.770
    Apr 2003
    1357
    Something is definitely wrong with your post. Your tool is dropping to Z0, moving over in X and Y, then going up 3mm, feeding back down slightly to 2.23 then starting the cut. Can you attach your post? It's probably just a matter of reordering some moves.
    Dan
    Oct 2010
    Stupidity was to blame
    I was reading someones instructions for madcam which said to set the home position (on the posting screen) to 0,0,0 or at least I thought it did... It actually said in this case the home position is 0,0,0
    The numbers which madcam generates for the home position should be left alone correct? The possible exception being the z height which I may want to increase to just to be on the safe side?
    Thanks for the quick reply!
    Apr 2003
    1357
    Maybe that's all it was. Try a path leaving the numbers alone and see what happens.
    Dan
  1. Trade offs between Moving Gantry and Moving Table
    By gregmary in forum DIY CNC Router Table Machines
    Last Post: 04-22-2011, 07:48 PM
  2. Moving Table, or Moving Gantry? (For Router)
    By Cryptonic26 in forum DIY CNC Router Table Machines
    Last Post: 04-20-2011, 08:38 AM
  3. DYNAPATH 20, WHEN E-CODE IS ENTERED, POSITION DISPLAY DOES NOT UPDATE.
    By WEBBERS_14 in forum Uncategorised MetalWorking Machines
    Last Post: 08-28-2008, 04:09 PM
  4. Discussion of moving table vs moving gantry
    By rkremser in forum DIY CNC Router Table Machines
    Last Post: 02-20-2008, 10:59 PM
  5. Moving Table vs Moving Gantry; Dremel vs Router
    By chuckknigh in forum DIY CNC Router Table Machines
    Last Post: 03-28-2007, 02:48 AM
