586,043 active members*
3,687 visitors online*
Page 3 of 3 123
Results 41 to 47 of 47
  1. #41
    Mar 2014
    35
    Re: prototrak plus 2axis mill
    What codes does yours use for bolt circle?
  2. #42
    Jan 2014
    20
    Here is a basic BHC program output from my proto+ manually put in and then exported. I found i have a prob in my processor with BHC.... getting error 14 at line 2 so it is not sending the correct info from the dwg. So back to enroute and SWI we go LOL
    BASIC BOLT CIRCLE
    PN0 G20;
    N001 G104 XC2.0A YC-2.0A HL05 R2.0 A0 T01 ;
  3. #43
    Mar 2014
    35
    I wasted 4 hrs yesterday and found that when I start a bolt circle at an angle greater than 262.1* it will error at that line and upload at 0* and no lines after.
    Now i have no problems.
    Thanks to all.
  4. #44
    Jan 2014
    20
    Re: ProtoTrak failure
    Ok, so if understanding correctly, as long as the start angle is 0 to 260 there should be no problems.....
    Mine is a bit different as its the enroute processor that is not sending the correct info at the moment, wo being worked on :-)
    And yes, some very good info in this thread. Hope it can help out others as well.
  5. #45
    Mar 2014
    35
    0-262.1* Is the safe zone. 262.2 + Will give me an error.
  6. #46
    Sep 2020
    I know it's an old thread; worth a shot!
    I'm having trouble transferring a program from my PC to a ProtoTrak Plus. I'm using a command prompt with the command "COPY {file} COM1". The PT+ will still just sit at the "RDY TO RCV" forever until I cancel the operation on the PT+.
    Program (this is exactly the same program I received from the PT+)
    PN0 G20;
    N001 G109 XC0I YC0I R3.0 DR1 TC0 FC0 F5.0 D1.0 T01 ;
    I have no problems sending from the PT+ to my PC; programs transfer perfectly fine. In order to receive the file I use PuTTY and the program code will appear in the console once I send from the PT+. I have one of those cheap in-line serial testers but don't really know what to make of the LED patterns. The tester does show activity when both sending and receiving. Port settings are correct and I do have the PT+ manuals.
    For hardware: I'm using the following USB-DB25 null modem cable: https://www.amazon.com/Converter-Apd.../dp/B07KYR6B1G coupled with a straight-through female-to-female adapter. I'm running from a Windows 10 machine. I was wondering if the USB-Serial cable is the issue, but if it was I would think I'd have problems sending from the PT+.
  7. #47
    Sep 2020
    To clarify where I'm at with the serial tester:
    The PT+, the serial tester checks out: TD is green, all other test lights off.
    The USB-DB25 Null model doesn't exactly check out: RD is green (good), DSR and CD are red (not good). Per the manual RTS, CTS, and DTR should be red or green, not DSR and CD. That said: it looks like the PT+ doesn't use RTS, CTS, DSR, CD, or DTR anyway; first pair and last 3 are each jumpered together (loopback). This being the case, I would think that it shouldn't matter what these look like on the cable side. But if the manual calls out the pins status, then it must be important??
    *note - i'm using the Step 3 check because my USB-DB25 is a null modem cable; I can't use the Step 2 test since there isn't a "raw" DB25 on the PC
    I'm at a point where I'm thinking I'd get a straight-thru USB-DB25 and use a breakout board to route signals accordingly, but would help if anyone who knows more about serial comms than I do to weigh in.
Page 3 of 3 123
  1. Prototrak mill
    By rzugnoni in forum Uncategorised MetalWorking Machines
    Last Post: 04-17-2014, 07:32 PM
  2. PC program for PROTOTRAK DPM5 Mill?
    By Gos in forum Uncategorised CAM Discussion
    Last Post: 01-22-2011, 06:06 PM
  3. Replies: 2
    Last Post: 10-30-2008, 04:19 PM
  4. Replies: 0
    Last Post: 10-25-2008, 01:03 AM
  5. Help With Prototrak Mill
    By wireguy2 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-05-2006, 04:14 AM
