Hey All,
Sure hope someone can help me again. I have a RM1204 ballscrew from linearmotionbearings2008 on ebay (Chai). The nut on the end of the ballscrew will not stay tight. I've tried to turn the bearing block around, but on the other side, the nut sits in an indentation in the bearing block and I cannot get the set screw tightened.
When the ballscrew starts turning, the nut comes loose and then the ballscrew starts sliding back and forth in the mount (resulting in GOBS of backlash!)
I've tried to tighten the nut down fairly snug and I left it so it just made contact with the bearing. I also put a washer between the bearing block and the nut...it all ends up being the same. The nut will eventually work its way loose.
I've tried to tighten the set screw as tight as I can get it without having the allen wrench jump.
Sorry for the crappy pictures, but it is the best I could get.
I'm contemplating drilling out the set screw hole and putting the next size bigger in. Maybe I can tighten it just a little more.
Any other ideas?
Mike
