586,077 active members*
3,711 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > simple micro limit switch wiring question
Results 1 to 10 of 10
    Jun 2010
    1414
    I have the micro limit switches from Keling
    I am curious how to wire them to the Sound Logic Break out board. http://campbelldesigns.net/files/bre...user-guide.pdf
    I have a limit switch for both ends of each axis. From what I know of any type of cut-off switch, they are generally ground (like hood pin switches in your car). There are three connections per Axis limit on the breakout board. Do I simply ignore the 12V of the limit or wire as such:
Name:	X limit 01.png
    At least in this fashion, if the SIG accepts either + or - it will know whether it has reached the X+ or the X- limit. Do I have the right idea?
    Nov 2010
    ignore the 12v + terminal on the board. You only need the signal and ground terminals.
    The 12+ is used to power a proximity switch.
    signal to NO on both the micro switches
    ground to the common on both the switches
    Oh just opened the link to the board, its on the last page
    Jun 2010
    1414
    So just the grounds are being used?
Name:	X limit 02.jpg
    And has anyone ever used JB Weld to secure a limit switch in place?
    Nov 2010
    that'll do the trick
    Nov 2010
    should add, its the "ground" that gives the signal that a limit has been reached. If you were to connect to a 12+ it may end up releasing smoke somewhere
    Nov 2009
    4415
    Use E6000 or a silicone based adhesive, JB weld will hold it but removal will be more difficult. The switch will need to be replaced at some time or plan for it anyway.
    Quote Originally Posted by nateman_doo View Post
    Feb 2006
    7063
    It's better to use normally closed switches wired in parallel. That way, if one fails, you'll know right away, rather than finding out the next time you hit the limits and it doesn't stop.
    Regards,
    Ray L.
    Mar 2004
    1806
    Quote Originally Posted by HimyKabibble View Post
    Regards,
    Ray L.
    Ray,
    Don't you mean in series? In parallel, you would not know if a switch even opened.
    Art
    Art
    AKA Country Bubba (Older Than Dirt)
    Feb 2006
    7063
    Quote Originally Posted by Bubba View Post
    Ray,
    Art
    Art,
    Yes, thank you. That's what happens when I type before my morning coffee....
    Regards,
    Ray L.
    Nov 2010
    'NC' in series to show a break in the signal during limit, 'NO' in parallel to show a signal during limt.
    if a normally closed switch fails, it stays closed unless on a trip in which it will stay open, vice versa for the opposing terminals. If one fails you will only see it when it does so in its fault position.
    It depends on whether you want a signal during limit or to lose the signal during limit
  1. MICRO Adjustment of Lever Type Limit Switch
    By scratch_6057 in forum DIY CNC Router Table Machines
    Last Post: 05-16-2007, 02:47 PM
  2. Limit Switch Wiring
    By The Speaker Guy in forum CNC Machine Related Electronics
    Last Post: 01-07-2007, 11:11 AM
  3. Simple Limit switch Idea
    By Nono in forum CNC Machine Related Electronics
    Last Post: 06-29-2005, 10:38 AM
  4. Home limit switch wiring.
    By DAB_Design in forum Mach Software (ArtSoft software)
    Last Post: 12-23-2004, 12:48 PM
