586,317 active members*
3,282 visitors online*
Results 1 to 7 of 7
    May 2010
    14
    Jog shuttle quirk
    Recently, I have been on two odd projects that required primarily manual milling. Numerous times the jog shuttle has ceased to function for all axis. This may happen anywhere and it is not related to a limit switch. Usually two clicks on the Reset button brings it back, however most often the interdial for step jogging stays non-functional. While these projects do not require tight tolerances I have bumbled along. The only way to regain the step jogger is a complete restart of the machine and computer and then it does not last!
    The only thing I found in the manual that may relate is Appendix 9.6.4.8 "Unexplained stop ...". This paragraph suggest the addition of a Ferrite supressor or a second parallel cable in series.
    Has anyone had an experience like or similar to mine? Comments or ideas how to fix?
    Ron Moss
    Oct 2008
    34
    I don't have a solution to the problem but I have had similar events. It seems like the communication between the computer and machine is lost. Even MDI commands don't work.
    I record the axis positions, restart Mach3 and re-enter the positions.
    Len
    Sep 2008
    20
    All it takes is an inadvertent press of the spacebar to cause something like this (Feedhold).
    There is no indication that you are in Feedhold other than everything appearing to be "locked up".
    Clear and Reset brings it back.
    Feb 2007
    1538
    Hi - I bought a spare jog shuttle, computer and keyboard.. so if I ever have an issue I can more easily eliminate what is not at fault.
    Another benifit is that murpheys law dictates that I will now never have any issues. (perhaps I am now tempting fate) !
    Jul 2007
    131
    Hello, I was also having this problem with my series 1 machine.
    What fixed it for me was changing the computer BIOS USB setting to "Full Speed (12Mbps)' instead of "Hi Speed (480Mbps)". Lowering the transfer rate is a common way to help with long cables.
    My shuttle is plugged into port on the keyboard. Then the keyboard needs a extension USB cable to reach the computer. Not that I've measured the total length but I'm guessing it's over 10'.
    Tormach PCNC1100, Mach 3 R3.043.037, MastercamX5 level 3.
    Feb 2008
    154
    I have the same problem with my pcnc 770 and the shuttle pro. I will try your suggestion btu44.
    Sep 2010
    I get issues like this when working manually between the Shuttle Jogger and inputting of commands in the MDI.
    Not so much the RESET button or even the E-Stop then RESET... I find that if you click the STOP key in Mach3 it corrects this and all motion comes back.
    Just Click STOP with the mouse, and continue on.
  1. lathe spindle drive / x axis quirk
    By davesnd in forum CamSoft Products
    Last Post: 08-31-2010, 12:45 PM
  2. M30 code quirk with coolant
    By Camber in forum Fanuc
    Last Post: 11-14-2008, 06:59 PM
  3. Robot quirk...Multiplex 6200 (Y)
    By CNCMP Scott in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-07-2008, 01:30 PM
  4. Mathematical Quirk?
    By Jim Estes in forum BobCad-Cam
    Last Post: 12-11-2005, 06:26 AM
  5. A small quirk with Mcode setup..
    By murphy625 in forum CamSoft Products
    Last Post: 04-03-2005, 04:14 PM
