I finally got some fuses and got my Mori MV 35 back in operation.
Power up and everything is fine and working.
I accidentally over traveled Y axis with the wheel. The screen changes from the X, Y, & Z screen that reads the co-ordinates as the table and Z column moves to the alarm screen, everything normal as it should be.
alarm 220 Y travel limit goes on, I reverse table direction with wheel and press reset and alarm goes out, OK and Normal
The question is should the X Y & Z screen now come back up or do I need to push or re-set something else?
I just turned off the machine and turned back on and got the X Y Z screen back up. There must be someway to return from the alarm screen to the normal X Y Z screen?
