Look at Pr.57 and see if the motor current is set high enough.
Set the display to to show current.
How much is it drawing?
Display is A x.x where x.x is the current being drawn.
What is the rated motor voltage on the name plate?
What model VFD are you using?
What is your mains supply voltage?
The manual is quite comprehensive.
Have you read it?
There are many parameters to set up to make it work correctly.
You need to follow the the manual, and it should work, providing the motor matches what the VFD is set for.
The default VFD settings may not match your motor requirements.
Some configuration is usually required, and from the number of parameters you can set, you will realize it is not trivial.
Good luck.
