586,645 active members*
1,977 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Can you compare this two linear motion parts
    Jul 2003
    246
    Can you compare this two mechanism.
    What are the advantages and disadvantages?
    Oct 2004
    742
    Bunalmis:
    If I were purchasing a unit, I would purchase the unit in the first photo. (with motor)
    Both units require extensive machining and accuracy to fabricate. My personal preference is linear bearings because they are self cleaning and very accurate. I do not see any disadvantages in Photo 1 except that it will be more expensive to fabricate. I also believe that it would require less maintenance.
    Photo #2 with roller bearings are not self-cleaning and can become covered with particles from the material being machined. Also, one would have to deal with alignment problems with all the roller bearings. Additionally, there is a possible problem with repeatability and accuracy.
    Jerry
  1. Linear Motion FAQ
    By Cutters Cove in forum DIY CNC Router Table Machines
    Last Post: 03-08-2018, 02:14 AM
  2. Using Linear motion assemblies
    By redbaron in forum DIY CNC Router Table Machines
    Last Post: 01-20-2004, 09:14 AM
  3. Linear motion
    By Wez in forum DIY CNC Router Table Machines
    Last Post: 12-07-2003, 07:54 AM
  4. Recirculating Ball Linear Motion
    By thielert in forum DIY CNC Router Table Machines
    Last Post: 11-27-2003, 11:13 AM
  5. Using 80/20's Linear Motion
    By EvanRobert in forum DIY CNC Router Table Machines
    Last Post: 07-01-2003, 08:56 PM
