Donnelly,
I commend you on your entrepreneurial spirit. Also, congratulations on the success of your business. I have started a few businesses over the years, and I still have one, Precision Plasma LLC. The best piece of advice that I can give you is to get product liability insurance. Since you are producing products which could harm people if they fail, you are at risk of being sued. It would be a shame to work so hard to build a business and to then have it taken away.
I also understand your comment that you can build a plasma table for less that what is sold by precision plasma...you can. If you want to build your own table as a learning experience, I would recommend designing and building one just for the feeling of accomplishment. If your goal is to make money, I would balance the time that it will take to design and build one versus the amount of money you could make producing your own products on the table in that same amount of time. If you really sit down and add up your cost and time, you may be surprised at what the most cost effective solution is.
I also want to clarify the pricing and features of the 2x3 table. We will be running a special on cnczone for the table kit which includes a wiring arm but no slats for $2500. This does include the 16 ga stainless water pan with integrated slat holders. If you wanted to purchase just the water pan from a vendor in your area in a quantity of 1, it would cost you $350-$500 depending on the vendor. Slats are 1/8" x 3" HRS, so shipping the slats cost as much as the slats themselves, so we don't sell them in the kit. This table is powdercoated and the frame is flat and square. The trick to welding, as you will learn, is to estimate how much the frame will move once the weld cools and to compensate for it. Also, you must be careful about how you design your frame to eliminate welding, which could bow your critical tubes.
This table was also designed with a c-shaped frame. This allows a full 4x8 sheet to be inserted and then supported with stands along the table. The upper portion can also be removed with 4 bolts and used as a portable table to be set on heavy material rather than trying to get heavy material up onto the table.
In order to save money, I suggest just using a handheld plasma torch. The cut quality is the same and it also allows you to do freehand if necessary. A handheld plasma torch can be installed or removed from our tables in less that 1 minute. We use a 1" clamp collar to hold the Hypertherm torch and a 3/4" collar to hold the torch cable. The rest of the cable then is supported on the top of the wiring arm with 2 broom clips.
You can't go wrong with the candcnc.com electronics package, but you will also want to purchase the Mach3/Sheetcam software package from them for $299. Draftsight.com is a free cad program that you can still use once you graduate, and the Hypertherm 45 is my plasma cutter of choice.
I hope this blog is helpful to you and good luck on your venture.
Best Regards,
Ron Chacich
P.S. There actually isn't much margin made on the 2x3 tables and we build them 10 at a time.
