Originally Posted by
skm
I do not think there is a way.
Fanuc controls treat each program space as inviolate, so you cannot write to other programs in the control.
And to write to within the same program would be to create self modifying code, which is not able to be done (works great in lisp on a computer, however) on a fanuc control.
The only things that I know you can modify are variables and using Dprint to send to a serial port.
A similar case is a probing program, the only way is to hook a computer to the serial port and send the coordinates from probing to that port.
The best you could do is save to a bunch of variables, one after the other, and batch-send them with Dprint. You said monitoring, so that is probably not helpful.
I don't know what you are monitoring--just if the machine is done? or which too it is on? Maybe something as simple as either an ethernet-camera pointed at the control, or a cheap EEEP netbook with a web cam, run VNC on it and login remotely to operate the webcam on another computer on your network (or from home).
Just an idea.
