586,077 active members*
3,793 visitors online*
IndustryArena Forum > CAD Software > Rhino 3D > Guitar Design using photos into Rhino
Results 1 to 6 of 6
    May 2007
    5
    Hi All,
    names Robbie from RIM Custom Basses in the UK, I currently trying to draw my custom bass templates using Rhino. I understand it will be better to upload photos and work on the designs this way. Im looking to build my own cnc machine next year and want to profile and cut out all the neck pockets and pickup cavities.
    Ive downloaded the rhino demo and managed to upload a couple of photos, just cant work out how to delete the background and highlight the profile of the guitar shape
    Any help would be great,
    http://i4.photobucket.com/albums/y13...d/IMAG0508.jpg
    http://i4.photobucket.com/albums/y13...d/IMAG0503.jpg
    My lastest work, 6 string marseer Custom
    Apr 2004
    5737
    It's not quite that automatic, Robbie
    You can bring in a JPG image as a background bitmap using the (you guessed it) Background Bitmap command, but you need to trace over it by hand, using the InterpCrv tool, to get a profile you can work with in Rhino. It doesn't take that long, and it works a lot better than any automatic raster-to-vector translation tool I've ever tried.
    Nice axe!
    Andrew Werby
    ComputerSculpture.com — Home Page for Discount Hardware & Software
    Quote Originally Posted by rim basses View Post
    Hi All,
    May 2007
    5
    Cheers for that, ive been having a go today and tracing out the design seems quite easy. Is there a tool to smooth out all the points, cheers.
    Robbie.
    Apr 2004
    5737
    Yes, try the Rebuild command
    Robbie.
    You can reveal the points of your curve (F10) and shove them around by hand to get as close as possible (zooming in helps - use the Z command and draw a box around the area you want to look at more closely). Then turn the points off (F11), highlight the curve you want to smooth out and Rebuild with fewer points. You can also smooth part of the curve by turning on the points, highlighting the ones in the bumpy area, and using the (you guessed it) Smooth command. Of course, if you want to preserve some sharp corners, keep those as junctures between separate curves, just make sure to snap the new one to the old one using the End Osnap. You can join them up later.
    Andrew Werby
    May 2007
    5
    Cheers for the help Andrew, ive been using the lasso command and smooth tool which seems to work well, i have a new issue when trying to design a guitar fretboard today using lines i couldnt seem to get the cursor to lock onto control points. I was looking at a guy on youtube building a fretboard and he seemed to have this function sorted, his cursor would highlight in red. gridsnaps are no good to me when the measurements are in between grids. Can you help me to figure this one out
    Cheers,
    Robbie.
    Apr 2004
    5737
    You need to find the Object Snaps
    If you have points laid out on the edge-line where you want your frets to go, use the Point osnap function; that will make the line start at the point. If you're just trying to snap to the edge-line, then use the Near osnap insread.
    Andrew Werby
    Cheers,
    Robbie.
  1. Tutorial: Rhino, Cut3D, and Vcarve Pro to make a guitar body..
    By konalure in forum Musical Instrument Design and Construction
    Last Post: 06-08-2010, 10:19 PM
  2. Can anyone help me here? (guitar design)
    By Ben J in forum Solidworks
    Last Post: 01-17-2008, 07:25 PM
  3. Solidworks guitar Design videos completed
    By CyborgCNC in forum Solidworks
    Last Post: 08-21-2007, 06:51 PM
  4. Irregula Guitar Surface on Rhino
    By NCN in forum Rhino 3D
    Last Post: 03-24-2006, 06:20 PM
