586,845 active members*
2,694 visitors online*
Page 1 of 2 12
Results 1 to 20 of 26
    Dec 2010
    Engraving Problem
    Hi, been studying this forum for the last couple of weeks and everyone seems very helpful.... anyway to the problem
    I have a DC-K40III machine running NewlyDraw 1.5 software, i've had some success engraving and cutting different materials but sometimes have a problem with the head movement in both X and Y. On some bmp files especially with lots of detail the head will move erratically all over the cutting area and also sometimes stalls and sticks in one position with the laser light still active and burns a hole through the material. I use CorelDraw to convert jpg images to B&w(1 bit) for the raster engrave. If i import the original jpg image and raster engrave that its fine but there is no shading detail so waste of material really.
    Could this be a data transfer issue ?(I have replaced the original parallel cable)
    Controller, driver or stepper motor issue or maybe a mechanical issue ?
    Any help would be greatly appreciated, thanks
    Jan 2006
    114
    Smile
    Hello,
    try the same file again with a lower speed.
    I think that the speed is to high for your stepper motors.
    Pierke
    Dec 2008
    1258
    It could be caused by a software problem due to the scanning.
    When you convert the file are you dithering it, and generating a file of the correct size?
    For example, if you are going to output it as 6" x 4" with a scan gap of 0.10mm then the image should be 1524 pixels by 1016 pixels.
    Another possible cause is you are running the machine too fast, 12cm/s is probably the maximum you should run.
    Does it work ok on big vector jobs?
    Zax.
    Dec 2010
    Quote Originally Posted by zax15uk View Post
    Zax.
    Hi Zax, when converting the image from jpg to bmp i resample the image to make it the size i want and then select a dpi of 300 for horizontal and vertical, either increase or decrease the contrast and brightness to make it look a bit washed out, then turn it to B&W with a jarvis conversion method then export it, When the export window comes up everything is as it should be but its still exporting as RGB 24, should i change this to B&W and tick the dither box or just export as default and see what happens ?
    Dec 2010
    Quote Originally Posted by Pierke View Post
    Hello,
    Pierke
    Thanks for the reply but i have tried different speeds, both faster and slower and i have also changed the direction it engraves too, from left to right with small steps on the Y axis downwards and up to down with small steps across the X axis (hope you understand what i mean). Really want to get this machine working properly as its my first even if it means changing boards
    Dec 2008
    1258
    Yes you want to save as B&W, no need to dither as you are already doing it with the Jarvis conversion.
    Why are you using 300dpi? The laser can do 127 (0.2mm), 254 (0.1mm), 508 (0.05mm) etc.
    25.4 / Scan Gap = DPI
    I would start at 127 dpi for most materials, although some may look better at 254 dpi.
    The flow you should follow is: first set the image size correct THEN dither, if you re-scale after dithering you destroy the file. Save without any further conversion, so the final image size should match the pixels per inch the laser is configured for.
    If you want to send me a bmp file to check, PM me and I will give you my email address.
    The laser should be scanning in the X-axis direction (moving the head) and stepping each line in the Y-axis (moving the beam). This allows the fast movement and acceleration with the lower mass.
    Zax.
    Dec 2010
    Hi Zax, thanks for the advice about SCAN GAP, I tried an image with a gap of 0.2 and it engraved all the image but without any detail..... I then lowered the gap down gradually and tried other engravings using the same image, at 0.15 still no detail so i lowered it again to 0.125 and this is where the head would start moving erratically again. I done 2 engravings of the same image and gap settings to see where on the image it starts messing up and on 2 seperate engravings it was always in the same place ?????
    Now i am really confused
    Dec 2008
    1258
    It sounds like a memory or buffer problem, probably made worse due to the conversion from pixels to laser.
    I would create the image correctly at 203dpi (scan gap 0.125) and test it.
    Zax.
    Dec 2009
    26
    Zax.
    is scan gap and line gap the same thing?
    my settings are scan speed, cut speed, scan delay, cut delay, and line gap
    Dec 2010
    Zax.
    Cheers Zax, i'll try that, i thought that NewlyDraw would recognise the dpi automatically and change settings accordingly, i am beginning to hate this software lol
    Dec 2010
    Quote Originally Posted by adayofjoy View Post
    I hope what you are saying is correct, my software doesn't say scan gap either so i am presuming line gap is the same thing and thats what i am changing
    Dec 2008
    1258
    Yes.
    In ND1 it is Scan Gap, ND1.5 it changed to Line Gap but they're the same.
    Zax.
    Dec 2008
    1258
    Quote Originally Posted by g1r9a6d8y View Post
    It will attempt to compress or expand the pixels to fit the output size but that destroys the dithering and won't yield correct results.
    If you do a lot of engraving it would be worth investing in Photograv as that does the conversion for you.
    Zax.
    Dec 2009
    26
    Yes.
    Zax.
    when i save in grayscale i get a complete burn but when i save in floyd or stucki , it starts jerking and i have stop.
    Dec 2008
    1258
    There should be no difference to the machine whether an image is saved as dithered or grey scale. If you reduce the speed does it run ok?
    Are you sure the pixel dimensions (image size) are the same when saved both ways, and both bmp format?
    Zax.
    Dec 2009
    26
    yes size is the same . i save as png
    should i save as bmp?
    it also does fine when i do victor
    Dec 2009
    26
    same speed too
    Dec 2008
    1258
    I would recommend BMP, just because I know it works. I've never had any problems with it but I haven't tried PNG. If I did I would only use a non-lossy compression (I think PNG supports both).
    Zax.
    Dec 2009
    26
    Zax.
    didn't help.
    everything is the same, open it in paintshop pro , size to 8 x 6 save in gray scale then save in b & w then save in floyd
    go to engrave printer setting on 127 x72
    prop settings 10 10 300 1 .01 mono
    jumped once in gray but then finished ( not a good pic. but not worried about that right now)
    when tried to run in b & w or floyde , jerked so bad had to stop.
    this is something new, i have dithered things before & ran ok
    even shut down every thing and tried again , no luck
    sorry to be such a pain but getting real frusterated , see can't even spell ha
    Dec 2010
    Zax.
    Hi Zax found myself a copy of Photograv so going to give that a go later today, will let you know how it pans out
Page 1 of 2 12
  1. PROBLEM ENGRAVING
    By REM in forum Mastercam
    Last Post: 11-04-2010, 12:20 AM
  2. Rotary Engraving Problem
    By coykiesaol in forum FlashCut CNC
    Last Post: 09-19-2010, 05:02 AM
  3. glass engraving problem
    By loyedp in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-13-2010, 10:49 AM
  4. laser engraving problem
    By fish09 in forum Engraving Machines
    Last Post: 02-04-2010, 02:02 AM
  5. Text Engraving II (Problem...HELP!) :)
    By BrassBuilder in forum Dolphin CAD/CAM
    Last Post: 01-02-2009, 02:44 AM
