586,096 active members*
3,523 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Spindle drive fault
Results 1 to 15 of 15
    Dec 2010
    28
    Spindle drive fault
    I have a mid 80's Hurco BMC-30, with a Fanuc Drive. I have an error: Spindle Drive Fault Check Drive System. When this happens there is an AL 02 code on the drive. I have a real nice Hurco repairman who knows that I can do most of these repairs myself I am just not very good at diagnosing the problem yet. He hooked me up with a guy from a place called Precision Zone inc, in Wheeling, IL. who said my drive was bad. I ordered one from him and replaced it. That was not the issue, it does the same thing. He mentioned something about the encoder being bad and he took the drive back. My questions are: Does anyone know where the encoder might be located I can't find it listed anywhere in the manual and maybe a good place to get one? If it is located in the motor itself should I just replace the whole motor? Any help will be great.
    John
    Dec 2010
    28
    OK, this morning I start it up and after calibration I can manually turn the spindle off and on without issue, which usually isn't the case, it usually errors out then also, but as soon as I run a program it does a tool change the head comes down and errors whenever the spindle is supposed to start. The error I get most is the Spindle drive fault Check Drive System, occasionally I get Agree System Failure.
    Jun 2008
    1104
    Sounds like a faulty orient card. Will it orient in manual mode?
    Jun 2008
    1104
    Alarm 01 (AL-01) Motor Overheat
    Causes
    Damaged motor fan, overload, motor cooler is dirty, loose connection.
    Remedy
    Replace parts, clean cooler, check connections, review cutting conditions.
    Alarm 02 (AL-02) Excessive Speed Deviation
    Causes
    Overload, transistor module is damaged, loose connections, error with speed feedback signal, blown fuse.
    Remedy
    Replace parts, check connections, review cutting conditions.
    Alarm 03 (AL-03) Blown Fuse in DC Link Section
    Causes
    Indicates that the fuse F4 in DC link is blown (models 30S and 40S).
    Remedy
    Check power transistors and replace fuse.
    Alarm 04 (AL-04) Input fuse blown / Input power open phase
    Causes
    Defective transistor module, blown fuse.
    Remedy
    Replace parts, replace fuse.
    Alarm 05 (AL-05) Control Power Supply Fuse Blown
    Causes
    Defective PCB, Abnormal power supply voltage.
    Remedy
    Check power supply, replace PCB, replace fuse.
    Alarm 07 (AL-07) Excessive Speed
    Causes
    Incorrect parameter setting.
    Remedy
    Reset parameter value.
    Alarm 08 (AL-08) High Input Voltage
    Causes
    AC power supply too high, incorrect setting of toggle switch for voltage setting.
    Remedy
    Change setting from 200V to 230V.
    Alarm 09 (AL-09) Heat sink is overheated
    Causes
    Cooling fan is defective, overload, dust and dirty.
    Remedy
    Replace fan, review cutting conditions, clean parts.
    Alarm 10 (AL-10) Input Power Voltage Low
    Causes
    Drop in input power, momentary power failure.
    Remedy
    Correct case and reset alarm.
    Alarm 11 (AL-11) Overvoltage of DC Link Circuit
    Causes
    High power impedance, PCB or transistor module are defective.
    Remedy
    Check AC power, replace damaged parts.
    Alarm 12 (AL-12) Overcurrent flows to DC Link Circuit
    Causes
    Output terminals or internal motor of motor is shorted, defective PCB or transistor module.
    Remedy
    Check connections, replace damaged parts.
    Alarm 13 (AL-13) CPU Inter Data Memory Alarm
    Replace PCB
    Alarm 15 (AL-15)
    Cause
    Spindle switch /output switch alarm.
    Remedy
    Check sequence.
    Alarm 16 (AL-16) RAM Abnormality
    Causes
    Defective RAM or PCB.
    Remedy
    Replace RAM, replace PCB.
    Alarm 18 (AL-18) Program ROM sum check error
    Causes
    Defective ROM.
    Remedy
    Replace ROM.
    Alarm 19 (AL-19)
    Causes
    Defective A/D convertor or PCB, loose connections.
    Remedy
    Replace A/D convertor, replace PCB, check connections.
    Alarm 20 (AL-20)
    Causes
    Defective PCB, loose connections.
    Remedy
    Replace PCB, check connections.
    Alarm 24 (AL-24)
    Causes
    CNC power off, defective optical cable.
    Remedy
    Turn power on, clean or replace optical cable, replace LSI, replace PCB.
    Alarm 25 (AL-25)
    Cause
    See Alarm 24
    Remedy
    See Alarm 24
    Alarm 26 (AL-26)
    Cause
    Defective signal level/line of spindle motor for C axis control, defective detector circuit for C axis control, incorrect parameter setting.
    Remedy
    Check signal level, connect signal cable securely, replace detector circuit, set correct parameter value.
    Alarm 27 (AL-27)
    Causes
    Position coder signal line defective, incorrect parameter setting.
    Remedy
    Connect signal cable securely, replace signal cable, set correct parameter values.
    Alarm28 (AL-28)
    Cause
    Defective signal level/line of spindle motor for C axis control, defective detector circuit for C axis control.
    Remedy
    Check signal level, connect signal cable securely, replace detector circuit.
    Alarm 29 (AL-29)
    Cause
    Overload.
    Remedy
    Review cutting conditions.
    Alarm 30 (AL-30)
    Cause
    Defective power transistor, defective PCB.
    Remedy
    Replace power transistor, replace PCB.
    Alarm 31 (AL-31)
    Cause
    Motor constrained, defective motor speed reversion signal/signal cable
    Remedy
    Connect cable securely, replace cable.
    Dec 2010
    28
    Yes I can orient/lock the spindle. I c an actually turn it on in manual (most of the time), just when I go to auto it errors out.
    Thank you for the reply,
    John
    Dec 2010
    28
    OK, today I finally got some time to mess with it a bit. I traced the cables from the drive to the motor and found no cracks or anything. I wiggled them around and just repositioned them a bit, and it has been running just fine all day. I don't know if it is just deciding to run for a bit after having a couple months off or not, but this is the first time I have been able to get more than one cycle out of it in 2 months.
    I guess now I need to maybe replace the cables. Does anyone know where I can find these, preferrably new ones?
    Sep 2012
    I have a Hurco BMC /D with a Delta 20
    Can not clear Spindle not ready alarm
    There is a F200 code on the varispeed
    Is there any hope
    OMF1
    Feb 2009
    6028
    What vfd is it?
    Sep 2012
    Varispeed 626 VM3
    Model CIMR-VMS27P5
    SPEC#27P50 621207
    Jun 2008
    1104
    That's a Yaskawa drive. Have you the list of error codes? If not, I can tell you.
    Sep 2012
    Yes it is and no I do not have them.
    Jun 2008
    1104
    It's an internal magnetic contactor failure. Look for the contactor (usually marked as an HV-75. A black block with terminals about 6"x4"x4") and see if it has any wiring issues. Also open the front cover of the drive and check the two fuses in the bottom (open the hinged panel to get to them) 1 1/4" glass fuses 4A). Check also that the spindle motor fan is running normally as the contactor and the fan are supplied by the two fuses).
    Sep 2012
    Thank you.
    I will let you know.
    Sep 2013
    11
    sir, i have an alarm fu in servo drive. pls tell me the rem,dy and tell the list of servo drive alarm .
    Sep 2013
    11
    sir
    i have an alarm spindle fault check servo drive. and drive shows fu alarm what should i do ?
  1. 1992 VF2 Alarm 123 spindle Spindle Drive Fault
    By dafowfidy in forum Haas Mills
    Last Post: 05-14-2012, 07:32 PM
  2. Spindle Drive Fault
    By bk1955 in forum Bridgeport / Hardinge Mills
    Last Post: 10-19-2010, 02:24 PM
  3. Replies: 4
    Last Post: 10-15-2010, 07:10 PM
  4. Spindle drive fault
    By Peat in forum Cincinnati CNC
    Last Post: 11-08-2008, 08:02 AM
  5. Spindle Drive Fault
    By n5jjr in forum DNC Problems and Solutions
    Last Post: 03-31-2005, 03:26 PM
