586,100 active members*
3,113 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Videos > Can I make a small suggestion?
Results 1 to 9 of 9
    Sep 2007
    44
    Wink Can I make a small suggestion?
    Would it be possible for those making a video of their machine cutting something to take a couple of extra seconds to show the finished part? To be quite honest, a CNC machine is a CNC machine. If the intent of the video is to show off the machine, maybe it is best to not have it cutting something. Too many times I find a video of a CNC machine machining a very cool object (I suspect), only to wait around for x minutes, seeing the machine make its final cut and then... Nothing... Video over.
    I know this comes across as a rant, and I apologize for this, but too many times I've watched x minutes of a cutter following a tool path only to be rewarded with a replay button in a black rectangle that was a video.
    Jul 2010
    369
    AYE!:idea::idea:
    And use a tripod
    :cheers:
    Sep 2007
    44
    A tripod is nice sometimes, but I can see it being a limiting factor, especially if the intent of the video is to show off the machine.
    However, if you are cutting something with your machine, it is perfectly reasonable for the viewer to expect to see the finished part.
    Nov 2005
    256
    And leave out the wiggly shot of the Mach 3 screen! Unless the video is about Mach 3 itself of course. If there is a point for showing the screen, at least tell us what we should be looking at.
    Ooh ooh, and no air cutting the road runner! Really cut the blasted thing.
    Oct 2007
    269
    :cheers:
    Could there be a reason the finished part is absent? I visit a local machine shop occasionally, mainly to see what they are running on their HAAS VF-2. It's cool to see the table in front of it full with complicated parts, some ready to go in, some that just came out. Then I go check out the actual running process, never a let down at that shop! Appetizer, main entree, and dessert.
    Jun 2007
    3757
    Talking I'll show the machine!
    Here is the machine repairing itself.
    SX3 Spindle nose grinding pictures by neilw20_2008 - Photobucket
    and the result.
    Sep 2007
    44
    Quote Originally Posted by cheetahcnc View Post
    :cheers:
    Typically, I would have to say no. On the videos I have seen, as soon as the machine is done or shortly before it is done, the camera is cut off.
    Oct 2007
    269
    I've seen plenty of CNC machined parts come out of a machine with an explanation of what went wrong to cause obvious imperfections, be it programming, machine, or operator error. All three of which have added to my experience ., which I would rather not have in a video.
    Jim
    Mar 2011
    wonderfull suggestion
  1. Can somebody make a small shaft adapter for me in the UK?
    By adamchapman in forum Uncategorised MetalWorking Machines
    Last Post: 06-14-2010, 10:43 PM
  2. What make of small plasma supply to get?
    By H2OMAN in forum Waterjet General Topics
    Last Post: 04-23-2010, 02:20 PM
  3. Machining Styrene to make small models
    By ALAN2525 in forum Material Machining Solutions
    Last Post: 01-23-2007, 10:08 PM
  4. Looking for some one to make small cap object.
    By dbtoutfit in forum Employment Opportunity
    Last Post: 03-30-2006, 12:45 AM
  5. Looking for some one to make small cap object.
    By dbtoutfit in forum MetalWork Discussion
    Last Post: 03-06-2006, 09:48 PM
