I just installed a Rosewill RC-302 parallel port card. I was only getting 4.4v and 3.4v out of the on-board parallel port. I am now getting 5v where I need it.
Anyway, I got the driver installed and I looked up the address and it has this listed:
Input/Output Range 2070-2077
Input/Output Range 2068-206F
Input/Output Range 2060-2067
Input/Output Range 2058-205F
Input/Output Range 2050-2057
Input/Output Range 2040-204F
Interrupt Request 21
In Mach3, I enable LPT2...but what address do I put in the block? It has 0x278 in there right now which really does match up with much of the above.
Do I check the block to enable pins 2-9 as inputs?
I am running Windows 2000.
I cannot find to see what the card is setup as....ECP....
And...there is a Microsoft RawPort driver that is missing once I install this card. Any idea what that is? Google is not telling me a lot.
Mike
