I finished the layout of the instrument panel last evening and cut it today. Took 3 hours and 45 minutes. Feed rate for the weave was 200 ipm and the hole pockets were 150 ipm. The 1/16" tapered ball nose cutter has been used a lot and the walnut was very stringy, so it will take considerable effort to clean up the weave. The owner took it home to do some of the sanding work himself and I told him not to do anything with the weave - leave that area for me to do. He will fit the holes to the instruments using his spindle sander. Turns out that the instruments are not 2" and 3.75" but are oversize by at least 20 thousandths.
He'll bring it back tomorrow and I'll work on it some more this weekend. The finish will be Deft clear lacquer unless someone tells me that it is a poor choice. The hot rod stays in a white enclosed trailer when not on the road.
