586,080 active members*
3,667 visitors online*
Page 158 of 158 58108148156157158
Results 3,141 to 3,151 of 3151
  1. #3141
    Apr 2007
    8082
    Re: CarveOne's Steel Channel Rebuild
    Hi Rusty,
    I could make use of a good telescope out here in the boonies. I have a good view of the sky when I turn off the outside lights.
    CarveOne
    http://www.carveonecncwoodcraft.com
  2. #3142
    Sep 2011
    1183
    Happy to see you back I need a bigger CNC 4X8or larger any Ideas build one or purchase one?.
    http://www.cnczone.com/forums/diy-cnc-router-table-machines/140832-cnc-software.html
  3. #3143
    Apr 2007
    8082
    Hi Gerry,
    Yes, a house swap at the same location. Winter rains and cold weather slowed down progress due to ground being too soft on some days prior to towing the old one out and towing the new one in. Some radio controlled crawler machines were used to move the halves while the tow truck stayed off of my site.
    CarveOne
  4. #3144
    Apr 2007
    8082
    Sounds good Arbo,
    I was following this and the Vectric site from my smart phone but didn't post anything due to it being too awkward on a small screen device. I'll be attending the McGrew Woodworks Aspire Camp in Columbia, SC in May.
    CarveOne
  5. #3145
    Apr 2007
    8082
    This site is full of ideas. That's where all of mine were hatched ... Check out the CNC Router Parts website for kits and/or parts to build your own. If you can weld and cut steel, go with steel box tube from a commercial source like I did.
    CarveOne
  6. #3146
    Jan 2008
    932
    Quote Originally Posted by CarveOne View Post
    Sounds good Arbo,
    Yeah I was looking to see what you were up to on the Vetric site... had not seen much in a while, now I know why. LOL.
    Anyway, have a good one, gotta go check on my machine, will post up what I am up to on my thread when I am done, if it works out.
    Wood neophyte.
  7. #3147
    Sep 2011
    1183
    CNC Router Parts I am looking at around 9K.
  8. #3148
    Apr 2007
    8082
    A 4' x 8' machine will not be very low cost unless you can do most of the labor yourself. That has been key for for me, since I already had the lathe and milling machine, welder, metal cutting band saw, and could make most of the parts for the frame myself using box tubing from a nearby commercial steel supplier. . I would consider $9k pretty reasonable since you only have to do the assembly of a kit from CNCRP. I paid $1k just for the paint job on my big machine, and that was just for paint supplies and rental of an automotive paint booth and lift back truck. A friend and I did all of the work at no cost to me.
    CarveOne
  9. #3149
    Apr 2007
    1955
    Quote Originally Posted by LouF View Post
    I think that for $9K, it is worth putting a little more thought into the linear motion components, especially the rails and slides. Don't just think about the router from a parts perspective, try to think about it 'in total", parts, assembly, alignment, and keeping it aligned. Sometimes just modestly more expensive parts can be dramatically easier to align.
  10. #3150
    Sep 2011
    1183
    I am also looking at the offerings from China.
  11. #3151
    Apr 2007
    1955
    I would also look at pacific bearing (PBC). Some of their simo products are pretty interesting.
  1. CRP2448 Rebuild: Welded Steel Base and Rackmount Electronics
    By Gerald V.B. in forum CNC Wood Router Project Log
    Last Post: 02-17-2013, 08:12 AM
  2. Moving Table Steel & Concrete Rebuild
    By JohnZ in forum CNC Wood Router Project Log
    Last Post: 07-04-2012, 09:55 PM
  3. encoder wiring channel A and channel B
    By senor J. in forum Gecko Drives
    Last Post: 12-13-2011, 04:30 PM
  4. Steel C-channel Build - Questions and pictures
    By olskool in forum DIY CNC Router Table Machines
    Last Post: 07-07-2007, 07:31 AM
  5. IRC channel for EMC
    By Dan Falck in forum LinuxCNC (formerly EMC2)
    Last Post: 12-18-2004, 06:03 PM
