Re: Manual ESTOP not activating
Technically you should have an E-stop hardwired circuit that operates the E-Stop relay, this relay should disconnect all motive power to drives, spindles etc, and advise the controller an E-stop has occurred.
IOW, it should not be entirely or solely a software input.
The E-string should keep the E-stop relay engaged until a E-stop occurs.
Albert E.
