586,104 active members*
3,403 visitors online*
    Mar 2009
    90
    Post Looking for info on ATC upgrade
    I'm looking for info from excitech atc cnc owners i need to know the spindle and vfd inverter parameters.
    Now i have a Delta VFD-B class inverter and HSD 6.5Kw spindle(italy, no atc). And i wanna upgrade to a 7.5Kw HSD spindle (atc system) but i don't know if my VFD will work. The VFD i have can handle 7.5Kw but the max. output frequency is 400Hz and all the HSD spindle (atc system) ar working at 800Hz.
    If someone has a ideea pleas share
    Sep 2008
    34
    Hi Mecanicu:
    pls check your delta inverter's version. Maybe you are going to change HSD ESE929 and it has a 4 poles motor, and you'd better ran it 24000rpm, 12000rpm is not good. for the delta inverter(VFD-B) have different version, some can change to 800hz, some cannot, and all their default value is 400hz.
    check it and send me an email: [email protected]. if it is the right version, i tell you how to change the parameters.
    Regards
    Alan
    Quote Originally Posted by king9558 View Post
    Hi Mecanicu:
    Regards
    Alan
    I have the same issue only spinning12000
  1. Looking for Info, Patent #'s, Info on Milling Machine Automatic Tool Changers
    By CNC-Joe in forum Uncategorised MetalWorking Machines
    Last Post: 08-22-2013, 05:41 PM
  2. Info required to upgrade this machine
    By zappafan1 in forum Benchtop Machines
    Last Post: 12-26-2011, 06:16 AM
  3. Upgrade!
    By erica18 in forum Cincinnati CNC
    Last Post: 07-18-2011, 03:51 PM
  4. Upgrade!
    By erica18 in forum SIEMENS -> GENERAL
    Last Post: 07-18-2011, 03:48 PM
