586,500 active members*
2,914 visitors online*
    CNC OSB semi-hollow TELE body
    Hi -
    I just started another TELE build on my CNC machine. This time I am using these drawings from this thread -
    D-Size Tele Body Blueprint Files HERE - Telecaster Guitar Forum
    I have been doing many adjustments on my machine and I think I have everything setup correctly. I also upgraded all my motors to Keling KL23H286-20-8B nema 23 425 oz-in.
    Page Title
    I will be posting all of my Mach3 and smooth stepper settings to my website in the next few days.
    Will have pics soon.... This will be a semi-hollow TELE body.
    Please check out my CNC blog
    http://cncinside.com
    The cutter got hot against the glued wood and burnt it.
    Attached Thumbnails Attached Thumbnails IMAG0910-2048.jpg   IMAG0917-2048.jpg   IMAG0923-2048.jpg   IMAG0930-2048.jpg
    This one will be a semi hollow body so I hollowed out a lot. Hope it all works out ok.
    Attached Thumbnails Attached Thumbnails IMAG0937-2048.jpg   IMAG0938-2048.jpg   IMAG0939-2048.jpg   IMAG0947-2048.jpg
    I am using a pine wood top on this one. Also I used to big of a cutter on the F. The next one will use a smaller cutter on the next one.
    Attached Thumbnails Attached Thumbnails IMAG0951-2048.jpg   IMAG0952-2048.jpg   IMAG0953-2048.jpg   IMAG0956-2048.jpg
  1. Tele cad drawings
    By Bdfamily in forum Musical Instrument Design and Construction
    Last Post: 02-06-2019, 11:40 PM
  2. Les Paul Hollow Body Copy
    By gregmary in forum Musical Instrument Design and Construction
    Last Post: 04-11-2011, 12:55 AM
  3. 72 tele pick guard
    By big_mak in forum Musical Instrument Design and Construction
    Last Post: 10-03-2010, 05:13 PM
  4. I need DXF's or DWG's or 3DM's for Tele parts
    By mgdesigns in forum Musical Instrument Design and Construction
    Last Post: 01-05-2009, 09:41 PM
  5. Semi-Hollow Singlecut Design
    By GuitarEng in forum Musical Instrument Design and Construction
    Last Post: 09-06-2007, 03:08 AM
