586,103 active members*
3,339 visitors online*
    Nov 2007
    26
    G code and tap files
    My CNC milling has been mainly profiles using AutoCAD and Mach 3 software.
    I have recently started to look at milling a mould that has some relatively complex profiles.
    In the past I have always modified G code by accessing notepad via the "Edit G code" button in Mach 3. These are then saved as tap files.
    I would now like to manually import fairly large amounts of data ie. x, y, z points from eg. word or excel filles into Mach for the G code.
    I have realised that I have no understanding of why the data is normally saved as a tap file.
    Can I just copy from other formats into Notepad and save as g code (tap)
    Any tips or pitfalls would be useful ?
    May 2004
    402
    Presumably the extension ".tap" harks back to producing perforated paper tape output for subsequent reading by an NC machine. Thus it will be in straight ASCII code, ie the same as saving ".txt" in Notepad.
    Andrew Mawson
    East Sussex, UK
  1. IGS FILES AND G CODE
    By vagelism22678 in forum Uncategorised CAM Discussion
    Last Post: 08-17-2011, 10:41 PM
  2. splitting g-code files
    By Gerbrand Nel in forum Mach Mill
    Last Post: 09-26-2009, 12:11 PM
  3. 2 g code files
    By Jaby in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 12-17-2008, 12:02 PM
  4. G-code files are required
    By uav in forum G-Code Programing
    Last Post: 08-26-2006, 10:38 AM
