586,052 active members*
4,267 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Aluminium extrusions plates tolerance stack up
Results 1 to 1 of 1
    Jul 2009
    24
    Question Aluminium extrusions plates tolerance stack up
    Hi all,
    my plan is to build and CNC machine from 8020 aluminium extrusions and aluminium plates.
    I have a quick question about the aluminium plate tolerances. The extruded aluminium has tolerance of 0.008"(Thickness) is that to much for the following build or do I have a tolerance stack up problem? See picture 1
  1. Aluminium Extrusions in Australia
    By ghassall in forum 80/20 TSLOTS / Other Aluminum Framing Systems
    Last Post: 01-10-2010, 11:15 AM
  2. Led light stack burned out on SL-10
    By Edster in forum Haas Lathes
    Last Post: 10-06-2007, 12:27 AM
  3. How do the linear slides stack up?
    By jsage in forum Linear and Rotary Motion
    Last Post: 01-30-2007, 11:57 PM
  4. Triple stack NEMA 23?
    By CharlieM in forum Stepper Motors / Drives
    Last Post: 12-23-2005, 02:13 AM
