Originally Posted by
bevinp
Randy,
Have you determined where the CofG of the mill is located? It makes sense that ideally the CofG should be aligned over the centre of the mounting feet (of the mill on the stand), but I wonder if the offset of the CofG from the ideal position is sufficient to cause a problem in head alignment. I guess that it would be very unusual for the mill to cut a vertical face more that 4" and over that distance, any affect of CofG offset would be negligible. Do you have any figures?
I too have set my mill about 0.5" high on the right to better drain the coolant. In doing this I noticed that the casting of the table tee-slots has a slope down to the right to enhance coolant draining through the table drain hole. I decided to block the existing hole and drill another drain hole in the rear wall of the table at the lefthand end. I made the size to suit a rubber hose (about 5/8" OD) and tied the other end to the handle of the chip tray over the stand drain. I now can have near flood coolant flow without the standard Deluxe stand tank running dry. I will replace that tank, one of these days ...
Danny,
I would not undo your wiring or change the planned layout of your shop. It really does not matter that the pads you will make for the stand feet will have significantly different height. Randy is right that it is more important to have the pads on the top of the stand coplanar. I found that the pads on my stand were out by about 1/8" and I put a metal plate on that pad. The Tormach supplied rubber gaskets should handle the minor differences that remained. Also I don't have the securing nuts tight.
Will,
If the new stand has clearance for pallet jacks then that is just another example of Tormach continuously improving their products (my mill is Series 1). Tormach really does focus on high quality products and excellent customer service. You made the right decision.
Bevin
