586,610 active members*
3,652 visitors online*
    Dec 2010
    First design - some advice?
    Hello:
    After studying lost of designs and based on the generous contributions in this and other websites, I decided to try one of my own, mainly because of availability and prices of parts here in Perú. I was not able to find threaded rods larger than 100 cms, so this was my main constrain. Also, I wasn't able to find a fixed base router, so I'll have to use a plunge router.
    I started to draw the design by hand, but it was too complex, so I decided to try Alibre. Never used CAD software before but online tutorials were very instructive and I was able to start designing very fast.
    So this is what I ended up with:
    - X and Y rails are stainless steel 20mm x 40mm x 1/16"
    - Z rails are solid aluminum 3/4" x 3/4"
    - Body of MDF or plywood
    - Router base (in light blue) is acrylic 1/4"
    - Angles are aluminum 1" x 1" x 1/8"
    - Z range is 15 cms
    - Y and X range close to 80 cms
    - My 3 axis electronics kit from cncrouterparts is on the way!!
    Still have to complete some minor details in the design, mainly screws and bolts.
    I want to cut wood for furniture and boxes, but my main goal is cutting aluminum sheets in the 0.60 to 1.0 mm thick range. I believe 0.1 mm precision will be ok for my purposes, but I don't know what will come in the future; so I tried to make it very stiff, but I am not sure if I missed something. I will be very grateful if somebody can give me some advice on my design.
    Also, my budget for software is limited and Alibre seems to be a good and inexpensive alternative. Does anybody have some experience with Alibre and CNC? I don’t think I will need to design very complex 3D parts. How well does Alibre work with Mach3? Any advice into inexpensive software for CNC will be appreciated.
    Attached Thumbnails Attached Thumbnails Total.jpg   Total2.jpg   x_rail.jpg   y_car.jpg
    way too flexible.
    A lot of people use it, but I pefer 1/4". you can twist the 1/8" angle in your hands pretty easily. With 1/4", you can't at all.
    Dust on the rails may be an issue.
    Dec 2010
    Hi, Gerry, thanks for your comments.
    Ok, acrylic is out. I think I can find 4 or 5 mm aluminum.
    I fear I will have to stay with 1/8" angle, is the thicker available.
    As seen in the attachment, the rails are covered by the bed (not sure if it is the right word). I suppose that will help, but the horizontal surface will trap floating dust. I will have to watch it carefully and consider adding dust control.
    Do you think the torsion boxes are ok, or maybe I am overengineering?
    Thanks, again
    You can never over-engineer.
  1. Hello My CNC design could do with some help and advice
    By caterry10 in forum Open Source CNC Machine Designs
    Last Post: 11-20-2010, 10:52 PM
  2. Design Advice Needed
    By dpgoldberg in forum DIY CNC Router Table Machines
    Last Post: 09-19-2010, 01:55 AM
  3. Design Advice Needed
    By JeLC in forum DIY CNC Router Table Machines
    Last Post: 03-03-2009, 05:39 AM
  4. Need advice with Z axis design
    By isvflorin in forum DIY CNC Router Table Machines
    Last Post: 01-09-2009, 01:47 PM
  5. design advice for a new builder
    By deft in forum DIY CNC Router Table Machines
    Last Post: 05-09-2003, 01:03 AM
