Need help/ here is what I've got: Mori Seiki Lathe Approx '82
with Fanuc 5T control. It was being used and controlled with a PC.
Between the buying transaction and the delivery, it seems like a cable on the BTR is missing, the only reference on the BTR is Facit 4070. It does not have a brand mark. The 50 pin wide cable is attached and a Db25 connector is also attached. Should there also be another flat wide cable to machine reader?
any help will be appreciated
Manny
