586,077 active members*
3,951 visitors online*
Results 1 to 6 of 6
    Jun 2004
    445
    Machining cast iron
    Hi there,
    In the next week or so, I'm going to be machining some cast iron parts on my mill using a 6mm endmill. I need some advice.
    My mill only has a max spindle speed of 2000 RPM. Based on this (and the fact that my mill is only a small Sieg X1 micro mill), what sort of feedrates should I be using to machine the cast iron (obviously only approximate)?
    I also read somewhere on the net that little to no coolant is required for cast iron. Is this true? It would be ideal if it is, as I don't have coolant on my mill. Would the occasional squirt of oil by hand be beneficial?
    Warren
    Have a nice day...
    Jun 2003
    1365
    about 1000rpm, 2-4ipm I am guessing, and no, you dont need coolant. cast iron is flakey and sandy so i dont know how long your tools will hold up.
    Jon
    May 2005
    1810
    Cast cuts really nicely - not the greatest of surface finishes though.
    Cover your machine and adjacent areas with something. It's a mess to cut....imagine ground up pencil lead all over your shop....
    Scott
    Consistency is a good thing....unless you're consistently an idiot.
    Apr 2003
    1873
    Warren, I just did some machining on a head, and they are right, it cut very easy, don't use coolant (gummy mess) It was a piece of cake and does not require a lot of horse power, you should get along fine.
    If you are using a carbide cutter 4 flute you probably could double the rpm and feed, 2 flute carbide you could increase the RPM some but not much on the feed. HSS in a 2 Flute is showing less then 2 IPM and 874 RPM so Jon's 2-4 X 1000 RPM is pretty close.
    These figures are not from experience but what I am getting from ME Pro software, usually a bit conservative, so it is great for us not so experienced.
    Ken
    Jun 2004
    445
    Hi there,
    Thanks for the replies, at least I now know where to start with the endmill.
    I was wondering if anyone knew how well grinding works with cast iron as well - using something like a dremel rotary tool. I intend to grind the surface once I have machined it.
    Warren
    Have a nice day...
    Using aluminum oxide grinding wheels worked great for me with cast iron.
    Proud owner of a Series II Bridgeport.
