586,103 active members*
3,339 visitors online*
Page 3 of 3 123
Results 41 to 50 of 50
  1. #41
    Feb 2006
    14
    Please I need your help.
    I replace the V3-40K AUTO Card
    but the machine does not responding, I can't move the axes
    and the control only shows this error " APPUYER SUR LE BP VOYANT ROUGE"
    I have tried to load the parameters, but I have not all the files.
    in the procedure for loading the parameters that refers to utilities files
    called UTIL0 and UTIL6, but I have not this files.
    Thanks for any help...
    Attached Thumbnails Attached Thumbnails AutoCard.jpg   Num750_Error.jpg   Steps.JPG
  2. #42
    Jun 2014
    18
    Re: I need help on NUM750 (machine REALMECA-C200V)
    Hello.
    (1)
    I have problem with lost UTILITES on NUM-750 (machine REALMECA-C200V),
    such as at post#35 (from ramley,03-21-2011) here--> http://www.cnczone.com/forums/commer...tml#post915257
    Startup screen is similar to:
    And I have tape-reader with lost tape coming with this machine.
    I don't know is it possible to use the set of utilites from another NUM-750 CN control (parameters no, of course).
    If its possible - I needed in binary utilites files
    (e.g. UT00.BIN,...,UT13.BIN as described at http://www.num-usa.com/EN_Tips/INTRE...tilityLoad.pdf).
    (2)
    After that - lost parameters on this NUM-750 REALMECA-C200V. Backup tape is missing (lost).
    Situation like as at post#37 (from Badlo,05-12-2011) here--> http://www.cnczone.com/forums/commer...tml#post939765
    Please help with detailed parameters manual and/or backup disks/files for this machine (NUM-750 REALMECA-C200V).
    (Backup/Restore procedure described at http://www.num-usa.com/en_tips/intre...up_Restore.pdf)
    On original NUM-750 cnc software disks must be present all of this, including utilites from above(1).
  3. #43
    Jun 2014
    18
    See my message #42.
    Startup screen is:
  4. #44
    Oct 2014
    Hello.
    I am new in this forum.
    I have similar problem like @ukr.
    My machine is "routron921s" with num 750f controller.
    I don't have UTILITES in RAM. And I have also other problem. When I try go to "direct PC dialogue" in I/O I have nothing on the screen. Some guy told me than I must restore the PLC . This is true?
    I don't have any backup.
    Can anyone help me?
    My e-mail addres: [email protected]
  5. #45
    Feb 2012
    6
    Hello, Have you solved your problem? I can send you some backup files from my NUM750.
  6. #46
    Jun 2014
    18
    Quote Originally Posted by DanielPereira View Post
    No. This problem not solved, insofar I know (I'm working now at another place).
    But shall is thanked if You send me this files.
    Share it, please, at RGhost — файлообменни� �º if it possible.
  7. #47
    Feb 2012
    6
  8. #48
    Jun 2014
    18
    Here is:
    link with 90 day of lifespan
    Thanks a lot, Daniel..
  9. #49
    Oct 2008
    7
    Hi to all.
    Have a LFU 3000 with NUM 750 ZAYER milling machine. Recently i was able to receive programs from machine,made a backup before changing the proces card. From then i canot receive programs from machine, but can send programs with no problem!
    Is there a missing file , or a macro?
  10. #50
    Hola que tal daniel espero te llegue este mensaje tengo una fresadora con control num 750 y se me perdieron los offset de la maquina mas precisamente se pasa de largo al momento de un set point en mi eje x y toca el sensor de emergencia. podrias pasarme los datos de respaldo de la máquina? ya que cuando la desarmaron no hicieron un respaldo. Aclaro de antemano que la tuve que desarmar por un problema en un optoacoplador de la placa de ejes.
    desde ya gracias
Page 3 of 3 123
  1. Weeke bp 10 NUM750 reference not starting
    By mar404 in forum Commercial CNC Wood Routers
    Last Post: 05-04-2019, 11:50 PM
  2. error code help num750 router
    By Hoverflyer.mk2 in forum Mastercam
    Last Post: 02-02-2015, 11:50 PM
  3. What means weeke bp10 num750 FEHLER 25 ???
    Last Post: 01-12-2011, 11:31 AM
  4. Num750.rmd
    By eng_semsem1980 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-08-2007, 10:01 AM
  5. I need help on NUM750
    By ahmedsamy_81 in forum DNC Problems and Solutions
    Last Post: 07-20-2005, 07:50 PM
