586,634 active members*
2,902 visitors online*
Page 1 of 3 123
Results 1 to 20 of 49
    Jul 2005
    20
    I need help on NUM750
    hello
    i need help on how to deal with num750,where i have french handbook but i need english manual.
    and i need help in where i can find english manuals for operating and programming SCM router.
    Oct 2004
    41
    Cool Num 750
    I have an SCM Record 2 and it has a NUM 750 control, I am told that there are some differences in the types of controls, what are you after and I can probably assist
    chris f
    Sep 2005
    you have scm - num 750 -- if you working in wood I have the same - Iam in EGypt - Cairo - Elopoor
    Jul 2005
    20
    Thanks mr.Omar Sanad
    yes i am egyptian and work in company near (6th october)
    please send me your phone or send me mail on
    [email protected]
    to take about how we can share informations
    Jul 2005
    20
    Quote Originally Posted by flinty
    chris f
    i need help for how i can obtain the english version for Num 750 handbook?
    and for my first program i face a problem in the tool change , where the magazin is rotatig contiuously without stop when the program start in toochane cycle, how i can solve this problem?
    Oct 2004
    41
    The tool change should be standard ISO programming that is for example
    T1 M6 for tool 1 M6 to change the tool.
    To try this out in MDI (manual mode) you select MDI mode
    and key in
    T1 M6 and LF ( enter) and CYC start.
    BUT you must press the cycle start key 4 times to action the command.
    You can also try entering M12 which should rotate the tool changer to position 1 after a full rotaion, or M15 which will move it 1 position.
    If you email me directly ( click on my name flinty above and send private email)( tell me what CNC machine you have) and you have a broadband connection ( for big file size).
    I will email you copies of programs which have tool change in them as well as a lot of NUM information and I am sure we can get you going easily, I am also happy to give you a copy of my post processor which is written for NUM750F and Mastercam Version 9
    Jul 2005
    20
    thanks ror your quick reply
    but can u send for me any help for num750 programming and operation in english
    Oct 2004
    41
    yes but I need you direct email address because I do not know how to attach files on the zone
    chris
    Jul 2005
    20
    my email address [email protected]
    Jul 2005
    20
    another note when i press MDI how i can write
    T1 M6 or M12 while the screen don't allow me to do that?
    Jul 2005
    20
    When will you send me the files?
    Oct 2004
    41
    I have a full set of Programming and operating manuals Xeroxed for you as requested.
    Please let me know when you are going to pay for them and I will ship as soon as I get your address from you.
    chris f
    Mar 2006
    7
    Hi, I have also a SCM Record 2 with a NUM 750 control for woodworking. I am using Alphacam 2004 and I need postprocessor for NUM750. Is there anyone out there that can help me ???
    Oct 2004
    41
    NUM post
    As mentioned above previously, I have a full set of the works manuals for this machine that I prepared for the SOB alchemy who then did not buy them.
    They are available for US$150.00 if you want them, because that is what it cost me to get them made.
    Now regarding your problem, I assume you have a legal copy of the software, and if so your supplying dealer can give you a post.
    I can obviously give you a Mastercam post which will run the machine perfectly, but it will not be understood by Alphacam.
    So how to fix this dilema is either you get the manuals and develop your own post from the programming manual so that your software knows what detail to put in the post.
    Or as said above go to Alphacam direct.
    Or Buy a copy of Mastercam Mill and I will give you the post.
    regards
    chris f
    Nov 2005
    Num 750f
    Hi I have a problem with num750f with the 3d Which code G for constant speed surface?
    Thanks Fabio
    Quote Originally Posted by flinty View Post
    and key in
    May 2008
    26
    Num Posts
    Found these.
    Jul 2005
    4
    Tray this
    I'm also Record 1 Num720 (very similar IIRC)
    operated it for coming on 10 years now - not sure why you cant enter text in MDI??
    Jun 2010
    51
    Hello,
    i need handbook for for Num 750 and advice. Reference did not starting.
    I spent half a day staring at mine and all it was was speed control knob set to zero :/
    internal fuse? no errors flashing on relays?
Page 1 of 3 123
  1. Weeke bp 10 NUM750 reference not starting
    By mar404 in forum Commercial CNC Wood Routers
    Last Post: 05-04-2019, 11:50 PM
  2. error code help num750 router
    By Hoverflyer.mk2 in forum Mastercam
    Last Post: 02-02-2015, 11:50 PM
  3. What means weeke bp10 num750 FEHLER 25 ???
    Last Post: 01-12-2011, 11:31 AM
  4. Num750.rmd
    By eng_semsem1980 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-08-2007, 10:01 AM
  5. I need help on NUM750
    By ahmedsamy_81 in forum DNC Problems and Solutions
    Last Post: 07-20-2005, 07:50 PM
