587,221 active members*
3,127 visitors online*
Page 3 of 3 123
Results 41 to 49 of 49
  1. #41
    Feb 2006
    14
    Please I need your help.
    I replace the V3-40K AUTO Card
    but the machine does not responding, I can't move the axes
    and the control only shows this error " APPUYER SUR LE BP VOYANT ROUGE"
    I have tried to load the parameters, but I have not all the files.
    in the procedure for loading the parameters that refers to utilities files
    called UTIL0 and UTIL6, but I have not this files.
    Thanks for any help...
    Attached Thumbnails Attached Thumbnails AutoCard.jpg   Num750_Error.jpg   Steps.JPG
  2. #42
    Jun 2014
    18
    Re: I need help on NUM750 (machine REALMECA-C200V)
    Hello.
    (1)
    I have problem with lost UTILITES on NUM-750 (machine REALMECA-C200V),
    such as at post#35 (from ramley,03-21-2011) here--> http://www.cnczone.com/forums/commer...tml#post915257
    Startup screen is similar to:
    And I have tape-reader with lost tape coming with this machine.
    I don't know is it possible to use the set of utilites from another NUM-750 CN control (parameters no, of course).
    If its possible - I needed in binary utilites files
    (e.g. UT00.BIN,...,UT13.BIN as described at http://www.num-usa.com/EN_Tips/INTRE...tilityLoad.pdf).
    (2)
    After that - lost parameters on this NUM-750 REALMECA-C200V. Backup tape is missing (lost).
    Situation like as at post#37 (from Badlo,05-12-2011) here--> http://www.cnczone.com/forums/commer...tml#post939765
    Please help with detailed parameters manual and/or backup disks/files for this machine (NUM-750 REALMECA-C200V).
    (Backup/Restore procedure described at http://www.num-usa.com/en_tips/intre...up_Restore.pdf)
    On original NUM-750 cnc software disks must be present all of this, including utilites from above(1).
  3. #43
    Jun 2014
    18
    See my message #42.
    Startup screen is:
  4. #44
    Oct 2014
    Hello.
    I am new in this forum.
    I have similar problem like @ukr.
    My machine is "routron921s" with num 750f controller.
    I don't have UTILITES in RAM. And I have also other problem. When I try go to "direct PC dialogue" in I/O I have nothing on the screen. Some guy told me than I must restore the PLC . This is true?
    I don't have any backup.
    Can anyone help me?
    My e-mail addres: [email protected]
  5. #45
    Feb 2012
    6
    Hello, Have you solved your problem? I can send you some backup files from my NUM750.
  6. #46
    Jun 2014
    18
    Quote Originally Posted by DanielPereira View Post
    No. This problem not solved, insofar I know (I'm working now at another place).
    But shall is thanked if You send me this files.
    Share it, please, at RGhost — файлообменни� �º if it possible.
  7. #47
    Feb 2012
    6
  8. #48
    Jun 2014
    18
    Here is:
    link with 90 day of lifespan
    Thanks a lot, Daniel..
  9. #49
    Oct 2008
    7
    Hi to all.
    Have a LFU 3000 with NUM 750 ZAYER milling machine. Recently i was able to receive programs from machine,made a backup before changing the proces card. From then i canot receive programs from machine, but can send programs with no problem!
    Is there a missing file , or a macro?
Page 3 of 3 123
  1. Weeke bp 10 NUM750 reference not starting
    By mar404 in forum Commercial CNC Wood Routers
    Last Post: 05-04-2019, 11:50 PM
  2. error code help num750 router
    By Hoverflyer.mk2 in forum Mastercam
    Last Post: 02-02-2015, 11:50 PM
  3. What means weeke bp10 num750 FEHLER 25 ???
    Last Post: 01-12-2011, 11:31 AM
  4. Num750.rmd
    By eng_semsem1980 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-08-2007, 10:01 AM
  5. I need help on NUM750
    By ahmedsamy_81 in forum DNC Problems and Solutions
    Last Post: 07-20-2005, 07:50 PM
