586,051 active members*
3,590 visitors online*
Results 1 to 8 of 8
    Jan 2006
    48
    driver power supply
    I have a 68volt rectified output that needs a bus capacitor of 7200uf , 91volt and 5amp ripple ,, if i can;t get the right size capacitor which way is it best to go, up or down in size (uf) derkiow
    24221
    I work it out that at 68v a 7200µf will produce 5% ripple at ~4.4amps load.
    at 10amps you would need around 16,000µf for 5% ripple.
    It depends on your load and the amount of ripple you want to design in at max current.
    One down side with going too large on capacitance is it requires an increase in transformer VA.
    Al.
    Albert E.
    Mar 2007
    2083
    Hi derkiow
    I just had a look at RS components
    and found item 381 - 9194 8200 uF 100V 18A @ £34-45 screw terminals
    with some values pcb mounting types are less expensive
    if for some reason you need to use a number of capacitors to make up the required value
    I would use 100 V capacitors in parallel that add up to the value needed
    Jan 2006
    48
    re
    So is it safer to go up or down would 6600uf do or would i be better going to 8800uf .The reason i ask is that have some 2200uf capacitors already ,,,,and thanks for the replies derkiow
    Oct 2005
    1237
    UP Always up. The more the better.
    24221
    Quote Originally Posted by MrWild View Post
    Except if you go too high and your transformer is tightly sized, you can go into saturation when running at maximum current.
    Quote Originally Posted by derkiow View Post
    What is your estimated maximum current?
    Al.
    Albert E.
    Jan 2006
    48
    i have three drives at 5amps so that will be 15amps and i have a 1kva transformer 45v @ 22amps my idea was to use 4 times 2200uf for each drive..derk
    24221
    For a 15a max load at 68VDC you would need 25,000µf for 5% ripple.
    100% rating would be 1.3kva and 60% duty cycle would require a .8kva supply.
    So it looks like you could go up to 25,000 for 5% ripple.
    Al.
    Albert E.
  1. Power Supply for HobbyCNC EZ Driver
    By trob4199 in forum Hobbycnc (Products)
    Last Post: 06-20-2011, 02:13 AM
  2. What type of power supply for my motors and driver?
    By bead in forum Want To Buy...Need help!
    Last Post: 06-06-2010, 03:20 AM
  3. Power Supply for Driver / Stepper
    By evocube in forum Stepper Motors / Drives
    Last Post: 11-03-2009, 01:29 AM
  4. Some power supply and driver Questions
    By gone4pepsi in forum Benchtop Machines
    Last Post: 03-22-2007, 04:48 AM
  5. Driver, PC LPT and power supply schematicas
    By msnarouz in forum Stepper Motors / Drives
    Last Post: 07-30-2006, 03:11 AM
